mikey1963
Message 1 of 24
IPv6 is active on Infinity 2 in Portsmouth
Great news everyone, seems that true to their word, BT have started rolling in IPv6.  I am using a Draytek Vigor 2860 as modem and router.
well done BT!
Cheers, Mike.
23 REPLIES 23
Message 2 of 24
Re: IPv6 is active on Infinity 2 in Portsmouth
likewise in Kent as well
gt94sss2
Message 3 of 24
Yes, I have had it live for a few days in SW London - on Infinity 1
My connection was also upgraded today to 55MB which I wasn't expecting to happen for a while.
mikey1963
Message 4 of 24
This plus the infinity changes are likely to woo quite a few people over I suspect.
Cheers, Mike.
dappelquist
Message 5 of 24
Hmmm... I can't seem to get it to work. I've got Infinity Option 2 in North London and I'm using an Airport Extreme with the supplied Huawei modem. I get “IPV6 Relay Error.” Did you do anything special to make it work?
@torgo
Tags (1)
mikey1963
Message 6 of 24
Not sure as I run a Draytek Vigor 2860 as router and modem. If there is a setting for ip6 then you really only need to put it on to a ppp setting to connect, everything else is automatic.
Cheers, Mike.
Message 7 of 24
Suspect it's a phased rollout?
mikey1963
Message 8 of 24
I imagine so but there are plent around the country that have reported ip6 connections to me. Seems they started enabling it with the faster infinity 1 speed hikes.
Cheers, Mike.
smf22
Recognised Expert
Message 9 of 24
I'd agree with webby in that it's phased and therefore pot luck whether you have it or not.
My connection with the latest BT Home Hub firmware still shows "IPv6 Configuration is not currently enabled as your BT Home Hub and/or BT Broadband Network are not enabled for IPv6."
Regards
Message 10 of 24
Not arrived in darkest Cambridgeshire yet.
