Message 1 of 2
Increasing Up and Downstream Sync Speeds
My BT Hub is currently has the following sync speeds:
Downstream: 50.2 Mbps
Upstream: 17.6 Mbps
When running a speedtest, I get the following speeds (which match the sync speeds above)
http://www.speedtest.net/result/7711940802.png
This is much lower than the advertised maximum speed, and lower than the openreach handback treshold as well:
https://imgur.com/a/20mS3ya
How can i get my line reset or the sync speeds increased?
1 REPLY 1
Message 2 of 2
Re: Increasing Up and Downstream Sync Speeds
post the stats from your hub  if hh6 then advanced settings then technical log information  if hh5 then troubleshooting helpdesk
are you using the test socket with a filter even if you currently have a filtered master socket to see if that improves your connection
have you been having problems with your connection dropping or doing manual resets or both?
do quiet line test  dial 17070 option 2  should be silent and best with corded phone
when you post stats post here and not link as easier to check instead of shunting between pages
