Cccrumpets
Message 1 of 8
Incredibly slow speeds at random times
Hi all,
I was wondering if any of you could help me.
I have 52mb fibre and have been consistently getting 48-50mb upload speeds for the last two months (since I got the package). But the last few days have been a nightmare with speeds. They drop down to such a slow rate that even a webpage won't load fully (I can't get on the wholesale speed tester when this happens). It doesn't seem to happen so much in the evenings, but during the day itself and it'll often start delivering speeds in the mid 40s during the late evening. I've tried speaking to bt directly but they have just sent out a new hub 6 which is suffering the same problem.
Any help would be really appreciated.. I only have so much hair left!
Thanks!
7 REPLIES 7
Message 2 of 8
Re: Incredibly slow speeds at random times
Can you post stats from your hub if hh6 then advanced settings then technical log information
Can you run btspeedtester and when first test completes then run diagnostic test and post results must be done with Ethernet connection
Sage
Message 3 of 8
Stats from hub?
Cccrumpets
Message 4 of 8
Thanks for your reply!
Tonight everything has repeated itself like clockwork with everything working fine up until about 6pm, where the internet is dropping out and then coming back in very briefly before cutting out again (dispite the blue light shining on).
I managed to run the speed test with varying results:
- When everything seemed to be working fine I had dl speeds of about 40mb and upload of about 5mb. After trying to run the diagnostics it said that I don't have FTTP to my address (which evidently isn't the case)
- In the intermittent stage when the internet keeps dropping and starting back up breifly, I had a result of 0mb dl and 0mb upload.
- Now whenever I try to run it I'm getting the error code #2032
Here is the technical log to hopefully shine some light on what it happening.
18:14:34, 23 May.DHCP device Connected: 192.168.1.150, ec:1f:72:c3:b1:c9,
18:14:32, 23 May.DHCP device Disconnected: 192.168.1.150, ec:1f:72:c3:b1:c9,
18:13:02, 23 May.admin login success from 192.168.1.215
18:12:37, 23 May.admin login error from 192.168.1.215
18:12:07, 23 May.admin timeout from 192.168.1.215
18:09:28, 23 May.DHCP device Connected: 192.168.1.215, 00:25:ab:64:d2:37,
18:09:28, 23 May.DHCP lease issued 192.168.1.215 to 00:25:ab:64:d2:37, lease duration is 86400 seconds
18:09:28, 23 May.Receive a DHCP request
18:09:22, 23 May.A device connected to Ethernet port 4
18:09:22, 23 May.Wire Lan Port 4 up, Speed 100 Mbps
18:09:22, 23 May.Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
18:09:19, 23 May.Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
18:09:18, 23 May.DHCP device Connected: 192.168.1.154, 18:cf:5e:59:99:ef,
18:09:18, 23 May.DHCP lease issued 192.168.1.154 to 18:cf:5e:59:99:ef Lauren, lease duration is 86400 seconds
18:09:18, 23 May.2.4G Client associate from 18:cf:5e:59:99:ef (IP=192.168.1.154) RSSI=-41, Rate=40Mbps, host
18:09:18, 23 May.Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
18:09:17, 23 May.Receive a DHCP request
18:09:16, 23 May.A device disconnected from Ethernet port 4
18:09:16, 23 May.Wire Lan Port 4 down, Speed 10 Mbps
18:09:09, 23 May.Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
18:09:08, 23 May.Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
18:09:08, 23 May.A device connected to Ethernet port 4
18:09:08, 23 May.Wire Lan Port 4 up, Speed 100 Mbps
18:08:20, 23 May.DHCP device Disconnected: 192.168.1.189, 00:17:88:28:88:b4,
18:08:19, 23 May.A device disconnected from Ethernet port 4
18:08:19, 23 May.Wire Lan Port 4 down, Speed 10 Mbps
18:07:49, 23 May.5G Client associate from 30:59:b7:8e:86:77 (IP=192.168.1.139) RSSI=-60, Rate=52Mbps, host
18:07:49, 23 May.Receive a DHCP request
And general info:
DSL uptime:0 days,23 Hours49 Mins29 Secs
Data rate:9.997 Mbps / 48.999 Mbps
Maximum data rate:16.960 Mbps / 49.006 Mbps
Noise margin:10.3 / 6.3
Line attenuation:30.2 / 20.9
Signal attenuation:29.9 / 20.6
Data sent / received:385.8 MB / 10.8 GB
Thanks!
Cccrumpets
Message 5 of 8
The internet has come back again and I managed to run the diagnostics based on my number rather than address. However, this time it gave some ludicrous result of 353.84 Mbps dl speed. I've sanity checked it against other speed checkers and they're coming out at around 45mbps atm.... Help!
Message 6 of 8
some browsers are giving false readings I suggest you try again using edge or Internet Explorer
Cccrumpets
Message 7 of 8
Thanks for the heads up! Edge is showing more accurate numbers (46.22 dl and 8.63 ul). Do you know what might be causing my issue?
buzzapb
Message 8 of 8
Had to conatct the Tech Dept. They said they would reset my connection and to see if it improves of the next few day.
Not sure what they did. Probably connected to the substation and reset their router. Has been back to norml since.
I used Sppedtest app on my mobile phone. That gives me a reasonably accurate reading. No browser interference.
Was running at 40meg down 8meg up for most of the day. Now at 12 and 7. They did say it would take 24hrs to settle back in.
Try www.speedtest.btwholesale.com that gives an accurate reading
