pwllheli
Message 1 of 5
Infinity 1: Renewing contract led to speed DE-crease
A couple of years ago BT replaced the line to my house and my (Infinity) speed has been a great 36Mbps down, 8Mbps up - significantly better than all my neighbours (whose lines were not replaced). I was well-pleased.
When I recently re-contracted with BT, with the advertised possibility of even higher download speeds, the person I spoke to said that faster speeds (<52Mbps) were not guaranteed and when he looked up my postcode, suggested that I'd be lucky to get 30Mbps and seemed to doubt my existing faster speed. (true: my neighbours don't get 32Mbps - but I got about 36Mbps)
After I switched, the download speed has indeed never been faster than 30Mbps - it is always 29.98Mbps or thereabouts.
(Upload more or less stayed the same at 7/8Mbps).
Has someone "done something" to my line to cap it at 30Mbps?
Is there any way to get this un-done, so that I get my previous 36Mbps (or perhaps even faster)?
Any suggestions appreciated.
4 REPLIES 4
Message 2 of 5
Re: Infinity 1: Renewing contract led to speed DE-crease
if you have a HH5 can you go to hub manager then trobleshooting then helpdesk and post 1-12
can you run btspeedtester and when first test completes then run diagnostic test and post results  must be done with wired connection  btspeedtester
can you enter your phone number and post results  remember to delete number wholesale FTTC check
try quiet line test   dial 17070 option 2  should be quiet and best with corded phone
pwllheli
Message 3 of 5
Thanks for immediate reply imjolly.
I have done what you suggested & list them below-
HH5 Helpdesk listing
1. Product Name: HomeHub5
2. Serial number: +076284+1429007161
3. Firmware version: v0.07.05.0A13-BT (Type B) Last updated 10/12/2015
4. Board version: 01
5. VDSL uptime: 0 days, 00:03:08
6. Data Rate: 8183 / 31824
7. Maximum Data Rate: 8183 / 37739
8. Noise Margin: 6.0 / 6.2
9. Line Attenuation: 28.6 / 27.0
10. Signal Attenuation: 0.0 / 0.0
11. Data sent/received: 0.6 MB / 2.4 MB
12. Broadband username: bthomehub@btbroadband.com
SpeedTest BT Wholesale
Best Effort Test: -provides background information.
Download Speed
29.46 Mbps
0 Mbps 30.8 Mbps
Max Achievable Speed
Download speedachieved during the test was - 29.46 Mbps
For your connection, the acceptable range of speedsis 21.56 Mbps-30.8 Mbps .
Additional Information:
IP Profile for your line is - 30.8 Mbps
2. Upstream Test: -provides background information.
Upload Speed
6.58 Mbps
0 Mbps 10 Mbps
Upload speed achieved during the test was - 6.58Mbps
Upstream Rate IP profile on your line is - 10 Mbps
Wholesale FTTC check - ADSL Checker
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
High Low High Low
VDSL Range A (Clean) 26.9 20 3 1.5 -- Available -- --
VDSL Range B (Impacted) 19.6 8.7 2.2 0.9 -- Available -- --
Featured Products
WBC FTTP Availability Date
Left in Jumper
FTTP on Demand 330 30 -- Available -- --
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 16.5 -- 9.5 to 19.5 Available -- Yes
WBC ADSL 2+ Annex M Up to 16.5 Up to 1.5 9.5 to 19.5 Available -- Yes
ADSL Max Up to 7.5 -- 6.5 to 8 Available -- --
WBC Fixed Rate 2 -- -- Available -- Yes
Fixed Rate 2 -- -- Available -- --
Other Offerings
Availability Date
VDSL Multicast -- -- -- Available -- --
ADSL Multicast --
Quiet line test
Seems OK to me...
Message 4 of 5
As you can see from stats you have almost 32mb connection speed which is way better than estimated speed and attainable is 37mb. With a stable connection you may get slightly more speed and move nearer attainable but noise margin is about normal 6db so makes it less likely
As you speed is better than top estimate then BT won't help
pwllheli
Message 5 of 5
Brilliant. Many thanks.
