eatmypig
Message 11 of 43
Re: Infinity 1 Speed Upgrade
I'm connected tothe master socket
Message 12 of 43
can you try connecting to the test socket and check if that improves your speed
eatmypig
Message 13 of 43
eatmypig
Message 14 of 43
That's the rating from the master socket, more or less the same from my untrained eye
Message 15 of 43
Can you post the connection stats from the hub when you have removed the faceplate from the master socket and connected to the test socket please.
eatmypig
Message 16 of 43
eatmypig
Message 17 of 43
eatmypig
Message 18 of 43
Stats as requested,
eatmypig
Message 19 of 43
As requested, connected to the master socket
Message 20 of 43
The test socket with the face plate removed?
You're currently banded to 22.4meg. The most your line will seem to handle is 39meg.
