eatmypig
Message 21 of 43
Re: Infinity 1 Speed Upgrade
Yes, i removed the face plate for the test, you say the most my line will handle is 39meg, when i go on the BT site and put my details it says the min guaranteed spped is 60meg 2017-02-28 (2).png
Message 22 of 43
Looks like you need an engineer visit then.
Have you checked for noise on the line by dialling 17070?
eatmypig
Message 23 of 43
My wife and I have just tried the line for noise by calling 17070 and it seemed fine by the both of us
Message 24 of 43
You need to raise a broadband fault and request an engineer.
eatmypig
Message 25 of 43
Will i have to pay for the engineer visit ??
Message 26 of 43
No, you've proved the fault is not in your wiring by connecting to the test socket.
Sage
Sage
Message 27 of 43
You will be advised of a possible charge but as you've proved no fault in your home by doing the requested tests then it will be free.
eatmypig
Message 28 of 43
Hi Pipping, how have I proved by doing the tests that the fault doesn't lie in my house ? , I know I've run a load of test but as I'm not tech savy it's strange , Id rather bite the bullet and stay on 20mb then switch when my contract expires than get hit unexpectedly with a bill for 130 notes , thanks for replying
Message 29 of 43
Because the fault still exists when you connect to the test socket. By removing the faceplate you have disconnected all your internal wiring that would be chargeable and are only connected to the Openreach responsible infrastructure. That is the purpose of the test socket, to provide a demarcation point.
Message 30 of 43
Just to confirm that by connecting to the test socket you've proven that the speed being delivered to the demarcation point (where Openreach's responsibility terminates) the issue HAS to lie on the Openreach line.
Switching supplier when your contract is up wouldn't resolve the issue.
