Johnoo
Expert
Message 1 of 32
Infinity 1 Stabalisation time
Just moved onto Infinity 1 from ADSL.
Was promised 32/45 Mb/sec Download speed with minimum of 29 Mb/Sec
Current statistics from Wholesale speed check
Download 27.2
Upload 7.44
Ping 22.75
From hub Noise Margin is 6.2/6.3, with Attenuation of 22.7
Will these statistics improve?
How long do I have to wait for system to stabilise?
31 REPLIES 31
Message 2 of 32
Re: Infinity 1 Stabalisation time
Hi Johnoo,
Please post your BT Home Hub 5 line stats: http://192.168.1.254 - Troubleshooting - Helpdesk.
Is the Hub connected to the test socket via a microfilter or via a SSFP?
Johnoo
Expert
Message 3 of 32
William,
Connected via Micro filter.
Referance Hub Statistics, can I send you via private message please, please believe I have a good reason
Or if you prefer send me a private message & I will reply with details & reason
Message 4 of 32
If you prefer, yes you can send me a private message.
Message 5 of 32
If you want users on the forum to offer help you will need to post the stats here. There is nothing in the stats that can not be shown on the forum. If you have changed anything that you don't want shown just blank out. If you are not using a Homehub just post the stats from the device that you are using.
Johnoo
Expert
Message 6 of 32
Having a great amount of trouble getting results to paste.
Hub Tech Log data is this:-
Data Rate 8.74/28.89
Max data Rate 8744/28892
Noise Margin 6.3/6.3
Only moved over to Infinity 1 today should I expect results in speed to improve over next few days?
Message 7 of 32
you need to post the stats from helpdesk if you want forum help as gg already said
also post dslchecker results
can you try test socket with a filter and see if that helps as it eliminates your setup and internal wiring as causing a problem
Johnoo
Expert
Message 8 of 32
Questions:-
1 Where do i find "Helpdesk" stats?
2 Ref DSL Checker results for some reason I can't find how to copy/paste these, get message that says "Ctrl+ V/Cmd + Vkeyboard"
I'm looking for help!
Message 9 of 32
To copy and paste, highlight all the text you want to copy then press the Ctrl and C keys together. Move your mouse to where you want to paste the information and press the Ctrl and V key together.
Johnoo
Expert
Message 10 of 32
Hope this is data required, when will stabalisation occur or will it stay the same, & should I contact for BT Engineer?:-
BT BROADBAND AVAILABILITY CHECKER
Telephone Numberon Exchange BLYTHBURGH is served by Cabinet 1
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  HighLowHighLow
ADSL Products
Availability Date
Left in Jumper
Other Offerings
Availability Date
VDSL Range A (Clean)44.732.48.86.1--Available----
VDSL Range B (Impacted)35187.63.9--Available----
WBC ADSL 2+Up to 3.5--2 to 6Available----
ADSL MaxUp to 2.5--1.5 to 5Available----
Fixed Rate2 ----Available----
VDSL Multicast------Available----
ADSL Multicast------Available----
