Message 11 of 32
Re: Infinity 1 Stabalisation time
now the information from the help desk page on your hub please
Message 12 of 32
go to hub manager then troubleshooting then helpdesk and post 1-12
Johnoo
Expert
Message 13 of 32
It's a Hub 6 & there is not a "Troubleshooting/Helpdesk"
Is this what you are looking for?
Data rate:
8.74 kbps / 28.89 kbps
Maximum data rate:
8744 / 28892
Noise margin:
6.3 / 6.3
Line attenuation:
22.7
Signal attenuation:
0 / 227
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
127 MB Uploaded / 540 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-G57T
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-G57T
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Band steering:
Off
Wireless mode:
Mode 1
Firewall:
On
MAC address:
90:72:82:94:71:DE
Software variant:
Boot loader:
7.33.1
Message 14 of 32
Yes.
With hh6 it is advanced settings then technical log
Message 15 of 32
Ard you using the test socket with a new filter to eliminate your setup and your internal wiring as causing the problem
Johnoo
Expert
Message 16 of 32
I am using a new filter, but it's not in the Master Socket my M/c is in a room away from the Master Socket
I've also got this from the Speed Checker, does it give more information to you?
1. Best Effort Test: -provides background information.
 Download Speed
 27.2 Mbps
0 Mbps27.97 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 27.2 Mbps
 For your connection, the acceptable range of speedsis 19.58 Mbps-27.97 Mbps .
 Additional Information:
 IP Profile for your line is - 27.97 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 7.37 Mbps
0 Mbps10 Mbps
Upload speed achieved during the test was - 7.37Mbps
 Upstream Rate IP profile on your line is - 10 Mbps
Message 17 of 32
The Hub needs to be connected to the test socket behind the master socket.
Message 18 of 32
Your current connection speed is blow bottom estimated speed but until you have used the test socket with a new filter and still connected below bottom estimated speed then getting engineer visit and the problem is found to be your extension wiring then you will get charged £129.99 for the callout
Johnoo
Expert
Message 19 of 32
But how can I connect a Tower Computer to the Master Socket that is in another room?
I am using a new Filter in the socket near to the computer, I did not have this problem with ADSL connection!
Message 20 of 32
Unfortunately VDSL and ADSL are different signals. ADSL can work on extensions however using extensions can affect VDSL signals. You are best to use the test socket which will rule out your extension causing the problem.
If you can not move your computer for test purposes are you able to "borrow" a laptop and connect that by Ethernet once the hub is connected to the test socket.
