Old_Welsh_dragon
Message 1 of 4
Infinity 1 speed dropped slightly over the last few days
I had a replacement HH5 type B on Tuesday, all was working fine up until Saturday night.
I had problem connceting to the internet, very slow, Youview box not connecting, no internet channels working, no catch up or EPG data.
A reboot brought it back, this morning had the same problem, reboot sorted it,
Got home from work thought I'd check my internet speed, normaly 37 Mbps now it's down to around 32-33 Mbps.
Has DLM been started ?
Hub stats ..
1. Product Name: HomeHub5
2. Serial number: +076286+1520013534
3. Firmware version: v0.07.03.0814-BT (Type B) Last updated [Unknown]
4. Board version: 01
5. VDSL uptime: 0 days, 00:18:04
6. Data Rate: 9995 / 34999
7. Maximum Data Rate: 14125 / 54143
8. Noise Margin: 8.7 / 9.9
9. Line Attenuation: 0.0 / 21.5
10. Signal Attenuation: 0.0 / 0.00
11. Data sent/received: 15.8 MB / 78.7 MB
12. Broadband username: bthomehub@btbroadband.com
3 REPLIES 3
Message 2 of 4
Re: Infinity 1 speed dropped slightly over the last few days
as an existing customer the change of hub won't affect the DLM is will be monitoring your line constantly.  these resets could easily triggered the drop in connection speed
Old_Welsh_dragon
Message 3 of 4
Is there anything I can do to get my speed back to where it was ?
Message 4 of 4
just maintain a stable connection and let the DLM do its job
