wiggy206
Message 1 of 20
Infinity 2 6Mbps speed help
Hi there I have recently had bt Infinity 2 installed and I'm only getting 6.62 Mbps speeds what could I do
Tags (1)
19 REPLIES 19
Message 2 of 20
Re: Infinity 2 6Mbps speed help
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
and use this speed tester then scroll down the page and carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
If you have a Homehub 5 can you post the stats from 1-12 by logging onto the Homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
or
If you have the Smart Hub, (Homehub 6) can you go to hub manager then advanced then technical log and post the stats. http://bthomehub.home/
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
If you have tried connecting to the master socket test socket and your problem is still there it would indicate that if there is a line fault it is not with your side of the master socket and you would not be liable for an engineer call out fee.
When you use the test socket make sure that any telephone extensions you have are "dead". There should be no dial tone at any of your extensions. If they have a dial tone it means you have star wiring and that is not good for Infinity.
Message 3 of 20
Is that the connection speed shown in router stats or download speed shown when downloading?
wiggy206
Message 4 of 20
wiggy206
Message 5 of 20
wiggy206
Message 6 of 20
Sorry it's as to posts
Zombie
Expert
Message 7 of 20
As @john46 says can you post the router stats please.
Is this an upgrade from standard broadband, as it certainly does not look like infinity 2 has been applied yet.
wiggy206
Message 8 of 20
Screenshot_20171213-200745.pngScreenshot_20171213-200745.pngScreenshot_20171213-200835.png
Message 9 of 20
@Zombie
the OP is on infinty look at the up load profile on the speedtest
Message 10 of 20
Try the hub connected to the test socket
