rcgood
Message 1 of 2
Infinity 2 Roll our program
I Rang yesterday and asked about the upgrade, i was told it is not available on my number. At present line is rated at 17.5mb dl
So is there a phased introduction for infinity 2?
rich
1 REPLY 1
Message 2 of 2
Re: Infinity 2 Roll our program
Infinity 2 is just BT's latest name for their FTTC service and is available wherever they have fitted fibre cabinets. If you are connected to a fibre cabinet and getting 17.5Mbps the upgrade will not help you as it involves increasing the speed cap from 40Mbps to 80Mbps. If you are not yet connected to fibre you will have to wait until they upgrade your cabinet if you post your postcode someone should tell you if the upgrade is planned.
