Morgen
Message 201 of 425
Re: Infinity 2: Speeds drop heavy in evenings?
BT's speedtester only shows speeds within BT's network and while that speed tester will show if its your line having a problem it will not show an issue if its a problem with BT's network, which in this case it is.
freddie5
Message 202 of 425
Also when you use the link "check for broadband service problems in your area" at the top left of this section it reports i have no faults - even though my dialling code (01332) is listed under the area codes affected by the Liverpool node problem?? Smiley Frustrated
19nbg71
Expert
Message 203 of 425
19nbg71
Expert
Message 204 of 425
my speed as of now .to say its frustrating is an understatement
SteveChapman
Message 205 of 425
Out of interest did BT say it was fine?
Locky
Expert
Message 206 of 425
Been about 50mbs today, now it's dropping off to 20mbs as of now.
Radio_Pirate
Message 207 of 425
Yep,another night of shocking speeds and packet loss again. Got a TBB ping quality graph running and can see the packet loss crept is at just before 3pm and has continued all evening onwards.
Good speeds on the BT speed test again but all the others are barley running at 10% of my usual throughput. My level of interleaving also went up after last night episode as think the DLM sees errors, collisions and retries due to the problems with the general back bone and assumes it's the line misbehaving rather than further down the chain.
All comes when Which & Ofcom are discussing customers needing to be told guaranteed speeds for contract rather than the usual marketing "upto" we are used too.
SteveChapman
Message 208 of 425
Joys back down to ADSL speeds... I miss ADSL2+
SteveChapman
Message 209 of 425
Interesting Nuneaton, Swadlincote and Atherstone had capacity upgrade yesterday and still slow speeds here in Nuneaton http://community.plus.net/exchange-information/
Meatboy
Message 210 of 425
Bah... tried the TBB Ping Quality but apparently i have a Dynamic IP and they don't support it 😕
Although at the moment here in Nuneaton (024) i'm still rocking 70+MB... although it went down hill around 7.30 yesterday so this may be a bit premature.
No packet loss as far as i can see but there is still time yet.
