jwynd
Message 1 of 9
Infinity 2 - Sync Speed dropped
Hi there all.
Over the past few weeks, I've noticed that my line speed (downstream) has dropped significantly from my usual ~55 Mbit.
According to the router, I've lost around 10 Mbit:
1. Product name:	BT Home Hub
2. Serial number:	+068343+NQ35114691
3. Firmware version:	Software version 4.7.5.1.83.8.236.1.2 (Type A) Last updated 12/07/17
4. Board version:	BT Hub 5A
5. DSL uptime:	0 days, 01:10:01
6. Data rate:	14993 / 45618
7. Maximum data rate:	16840 / 60345
8. Noise margin:	6.3 / 6.1
9. Line attenuation:	18.8 / 17.3
10. Signal attenuation:	18.6 / 17.3
11. Data sent/received:	66.5 MB / 512.7 MB
12. Broadband username:	bthomehub@btbroadband.com
13. BT Wi-fi:	No
14. 2.4 GHz Wireless network/SSID:	BTHub5-5TRT
15. 2.4 GHz Wireless connections:	Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:	WPA2
17. 2.4 GHz Wireless channel:	Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:	BTHub5-5TRT
19. 5 GHz Wireless connections:	Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:	WPA2
21. 5 GHz Wireless channel:	Automatic (Smart Wireless)
22. Firewall:	Default
23. MAC Address:	34:8a:ae:76:d0:66
24. Modulation:	G.993.2 Annex B
25. Software variant:	AA
26. Boot loader:	1.0.0
This speed is confirmed on the BT Wholesale speed test:
Nothing has changed with my internal network setup to cause this drop. However, in the past I've had issues with the DSLAM, though I'm struggling to recall how this was resolved? I've logged the 'fault' with BT, however the helpdesk guys that I've spoken with so far suggest there is little that I\they can do...
My connection remains stable, however I'm currently wasting money on the Infinity 2 package and I really miss the extra speed that I've reliably had over the past few years.
Any advice appeciated on steps towards getting this resolved.
Many thanks.
8 REPLIES 8
imjolly
Message 2 of 9
Re: Infinity 2 - Sync Speed dropped
the hh5 reset about 1 hr ago was that manual or hub dropping connection?  do you know if you hub has been dropping connection often recently?
try quiet line test  dial 17070 option 2  should be quiet and best with corded phone
have you tried using the test socket to see if that improves anything by eliminating your internal wiring as causing a problem
enter your phone number and post results  remember delete number  http://dslchecker.bt.com/adsl/adslchecker.welcome
jwynd
Message 3 of 9
Hi @imjolly
Yes - the HH5 reset was in response to my call with BT (standard troubleshooting). I usually have a stable connection, often lasting more than 14 days without a dropped connection or reboot.
I haven't tried the Quiet Line Test or the test socket. Will give those a go tomorrow, though I'm skeptical. Smiley Indifferent
Here's the ADSLChecker results as requested:
Thanks in adv.
jwynd
Message 4 of 9
FYI, Quiet Line Test appears fine. Can't hear any static or noise. Haven't had a chance to look at the test socket yet.
jwynd
Message 5 of 9
Hi there. Still get the same sync speed on the test socket it seems. Any other advice on next steps? I think I've ruled out this issue being internal to my network.
imjolly
Message 6 of 9
if you are nowconencted to test socket with a filter can you repost router stats for comparison
jwynd
Message 7 of 9
5. DSL uptime:	0 days, 00:01:44
7. Maximum data rate:	16660 / 60260
11. Data sent/received:	0.5 MB / 2.3 MB
13. BT Wi-fi:	No
Thanks in adv
jwynd
Message 8 of 9
FYI, this was finally resolved by an engineer visit. Line was 'reset' and moved from 'interleaving' to 'fast'.
JohnC2
Moderator
Moderator
Message 9 of 9
Hi @jwynd Thanks for good news and posting back to confirm how the issue was resolved.
Cheers
John
