RJ414i
Message 1 of 20
Infinity 2 Troubles.
I've had Infinity 2 for a few years with no problem and a steady 78Mbs speed until about 6 weeks ago.
Then the problems started, orange flashing light on Hub (HH6) and reconnections.
Speed down to 60Mbs and more reconnections and a occasional solid orange light with no internet then no lights at all. Power on/off and it all comes back to life. Line tested and no fault found. Three weeks ago Openreach changed the Hub for a new one, sorted i thought.
This week solid orange light on on Tuesday evening, contacted BT (Stockport?) line tested ok,power on/off and away we go. This morning Blue light on Hub but no internet, checked BT Sport on Youview obviously nowt. Contacted BT (India) who done another line test and found no fault. we will send out a new Youview box tomorrow.
Checked speed tonight now down to 47Mbs.
Do you think a new Youview box will sort it or am I in this for the long haul?
19 REPLIES 19
Moderator
Moderator
Message 2 of 20
Re: Infinity 2 Troubles.
Hi @RJ414i,
How has your connection been performing since Thursday night? If the speeds haven't recovered please take a look at our help pages: Five steps to improve slow BT Broadband speeds & BT Broadband Speed Hub.
Let me know how you get on.
DanielS
RJ414i
Message 3 of 20
Hi DanielS,
Thanks for getting in touch.
Openreach changed the Youview box on Friday.
Just looked at the Smart Hub Manager which is showing -
Downstream sync    49 Mbps
Upstream sync          17 Mbps
Network uptime       0 Days,  19 Hours,  17 Minutes
System uptime         0 Days,  19 Hours,  20 Minutes
 Don't seem to get a long run without a reconnection.
Many Thanks
Message 4 of 20
Can you post stats from your hh6. Advanced settings then technical log information
RJ414i
Message 5 of 20
Product name:
BT Hub 6A
Serial number:
+084316+NQ73989439
Firmware version:
SG4B1000B540
Firmware updated:
31-Oct-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 19 Hours 37 Minutes 50 Seconds
Data rate:
17.00 Mbps / 49.00 Mbps
Maximum data rate:
28832 / 77182
Noise margin:
13.7 dB / 13.6 dB
Line attenuation:
14 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
152 MB Uploaded / 3822 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-ZMTW
2.4 GHz wireless channel:
Smart (Channel 6)
5 GHz wireless network name:
BTHub6-ZMTW
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
58:90:43:F8:5D:60
Software variant:
Boot loader:
Sage
Sage
Message 6 of 20
Any noise on your line? 17070 option 2. best with corded phone.
RJ414i
Message 7 of 20
All quiet with a corded phone.
Message 8 of 20
From the stats you have posted you are in a banded profile due to the number of disconnection you have had.  Until you can find the cause of the disconnection and fix it you connection will not improve. Even worse if disconnections continue there is every possibility your speed will reduce further - until you can get a stable connection
Moderator
Moderator
Message 9 of 20
@RJ414i  Have you tried connecting the Hub directly to the test socket to see if that help with the disconnections?
RJ414i
Message 10 of 20
Hi all,
Just connected the hub to the master sockets 'test socket's, let's see what happens now with the connection.
