Message 1 of 21
Infinity 2 - degrading Broadband upload connection speed
Hi, for the past year or so I've enjoyed down/up connection speeds of 50-70Mbps / 12Mbps but since early July my HH connection speeds are showing 50Mbps/2Mbps. The major concern is the huge drop in uplink connection speed - spoke with BT Consumer Customer Service and they say no guarantees are offered on the uplink speed and therefore no fault can be raised, this is despite them acknowledging the upload speed was significantly higher in previous months.
I've done a re-start on HH, nearly 5 days later no sign of improvement. Config summary below, any ideas please? Seems to show I have the potential for 12 Mbps uplink but it's not training the speed up from what I can see.
Product name:
BT Hub 6A
Serial number:
+084319+NQ70236098
Firmware version:
SG4B1000B540
Firmware updated:
06-Apr-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
4 Days, 19 Hours 58 Minutes 9 Seconds
Data rate:
2.00 Mbps / 50.47 Mbps
Maximum data rate:
12241 / 52212
Noise margin:
19 dB / 6.6 dB
Line attenuation:
21.3 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
2227 MB Uploaded / 38455 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-C7S5
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-C7S5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
A4:08:F5:88:E2:07
Software variant:
Boot loader:
7.33.1
20 REPLIES 20
Message 2 of 21
Re: Infinity 2 - degrading Broadband upload connection speed
hi - can anyone explain why I'm getting 2Mbps uplink speed on a circuit that shows potential for 12Mbps?
Moderator
Moderator
Message 3 of 21
@RichBHit It looks like the upload profile may be banded to 2Mb. Please use the 'click here to contact the mods' link in my forum profile to send in your details and we'll be happy to get that looked into. You can find the link by clicking on my username.
Neil
Message 4 of 21
Thanks Neil, done
Moderator
Moderator
Message 5 of 21
Hi @RichBHit I called earlier sorry I could not reach you. I wanted to check it if you have seen any improvement in your upload speed. Post back and let me know.
Cheers
John
Message 6 of 21
Hi John, thanks for the help.
It did temporarily increase the upload connection speed to 10mbps from early yesterday however as of 1700 BST today the network connection was re-set and connection speeds are back down to 47Mbps down/2Mbps up.
I could wait to see if it trains up over the next few days but I'm not hopeful.
It's like there is an auto policy being applied that is limiting and policing my speeds - details below from latest log. Strange that my uplink speed is higher than the indicated max rates.
Product name:
BT Hub 6A
Serial number:
+084319+NQ70236098
Firmware version:
SG4B1000B540
Firmware updated:
06-Apr-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 43 Minutes 28 Seconds
Data rate:
2.17 Mbps / 43.15 Mbps
Maximum data rate:
278 / 51501
Noise margin:
5.4 dB / 6.1 dB
Line attenuation:
21.2 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
28686 MB Uploaded / 94349 MB Downloaded
Broadband username:
BT Wi-fi:
Active
BTHub6-C7S5
Smart (Channel 1)
BTHub6-C7S5
Smart (Channel 44)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
A4:08:F5:88:E2:07
Software variant:
Boot loader:
7.33.1
Moderator
Moderator
Message 7 of 21
Hi @RichBHit thanks for posting that update.
Please can you complete a speed test  for me using an Ethernet cable – once you have completed the speed test, please select the further diagnostic button to send your results over via our server and post back and let me know when you have completed it.
Cheers
John
Moderator
Moderator
Message 8 of 21
Hi @RichBHit I called earlier sorry I could not get to speak with you.
I wanted to check how your upload speed is. Please post back and let me know and if you are still experiencing slow upload please complete a speed test as per my last post.
Cheers
John
Message 9 of 21
@JohnC2
unless it has been fixed since yesterday the btspeedtster is faulty and giving rubbish results
Message 10 of 21
Hi, thanks will check and post back in a few days once I have a stable view.
