Fuzzy171
Message 1 of 11
Infinity 2 speed after 24 hours
I was connected yesterday and I am getting 32mb down and 8mb up. On my smart hub it says 34.5 and 8.6 so good enough. I was told I could expect between 56-70 down and 15-20 up with the minimum guaranteed speed of 56 down. Is this a resonable speed I'm receiving after 24 hours or should it be better?
Thanks in advance.
10 REPLIES 10
Distinguished Guru
Distinguished Guru
Message 2 of 11
Re: Infinity 2 speed after 24 hours
For the 1st 48 hrs you should be recieving a faster speed as DLM builds a profile and the adjusts your connection (if necessary) for stability.
Can you post your line stats from the Hub?
Fuzzy171
Message 3 of 11
Thanks for getting back to me but what stats from the hub?
Distinguished Guru
Distinguished Guru
Message 4 of 11
Use THIS link and post back a screenshot.
Fuzzy171
Message 5 of 11
Fuzzy171
Message 6 of 11
Message 7 of 11
Something not right.
Where is your hub connected? The master socket or an extension?
Fuzzy171
Message 8 of 11
Master socket
Fuzzy171
Message 9 of 11
Sorry it's at the master socket with a micro filter but I've ordered a new rj11 cable to see if it makes a difference.
Message 10 of 11
You need an engineer visit.
