Bouf111
Message 1 of 23
Infinity 2 speed drops from 50 meg to 16 at peak times - Bearwood exchange
Hi , recently my speed has been really poor at peak times and wonder whether my connection now is too congested, is there anything that can be done?
22 REPLIES 22
Moderator
Moderator
Message 2 of 23
Re: Infinity 2 speed drops from 50 meg to 16 at peak times
Hi @Bouf111 and welcome.
Can you confirm which exchange you're on? Can you try running the speed test including the further diagnostics when the connection is slow and post the results?
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Bouf111
Message 3 of 23
Hi,
I am on the Bearwood Exchange
Results
download speed 12.83
upload 16.21
Ping 17.63
also did further diagnositc with same results.
Surely this cant be right for infinity 2
Any help would be greatly appreciated
Pete
Message 4 of 23
you need to post the further diagnostics test results as that result is saved on BT Wholesales servers
Bouf111
Message 5 of 23
Hi these are the results from the additional test but as you can see there seems to have been an error.
FAQ
Results Image not loaded
1. Best Effort Test:
Download Speed : 8.45 Mbps
2. Upstream Test:
Upload Speed : 16 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
Moderator
Moderator
Message 6 of 23
@Bouf111 I'm sorry about the delay getting back to you. I can't see any issues reported with the Bearwood exchange but if there is congestion on the network it may be in a different location.
If you send over your details we'll be happy to get this looked into. You can find the click here to contact the mods link by clicking on my username.
Neil
Community ModeratorNeilO
Kudos”
Tlwil13
Message 7 of 23
@NeilO I've just opened up a new thread and then seen this one, we're on the same exchange and down from 50 to 4 for download speed so it doesn't appear to be an isolated issue.
Moderator
Moderator
Message 8 of 23
Hi @Bouf111 & @Tlwil13
From double checking there may be a potential congestion issue.
There is one particular VLAN on that exchange that BT Wholesale have identified as being over utilised.  So if both you guys are connected to that VLAN this will explain why you're seeing a slow down of your throughput speed during peak times.
@Tlwil13  Can you also send us over your details and we'll check this for you too?  Click on my username here >> RobbieMac << and you'll see our contact link on the left hand side underneath my profile picture.
Cheers,
Robbie
Community ModeratorRobbieMac
Kudos”
Tolla
Message 9 of 23
Re: Infinity 2 speed drops from 50 meg to 16 at peak times - Bearwood exchange
Hi robbie
I have exactly the same problem as Bouf111 and TIWIL13. I'm on the same exchange and from about 5pm till 12 am my infinity 1 speed drops to around 3 meg download and 6 meg upload.
Off peak it's back to normal at around 49 meg download and 10 upload. This has been happening all week.
Could I send you my contact details too?
Thanks.
Message 10 of 23
Tolla you will need to wait for a moderator to post their contact link before you can send in your details
