Moderator
Moderator
Message 11 of 23
Re: Infinity 2 speed drops from 50 meg to 16 at peak times - Bearwood exchange
Hi @Tolla,
I'll be able to take a look at this for you. Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
Message 12 of 23
@john46
Thanks will wait for the moderator to do that.
Message 13 of 23
@PaddyB
Thanks I have done that.
Moderator
Moderator
Message 14 of 23
Hi @Bouf111,
Thank you for sending in your details. I gave your mobile number a quick call, I'm sorry that I didn't get speaking to you today. I've checked with BT Wholesale and unfortunately they aren't reporting any capacity issues at your exchange. In order to get this investigated, please can your run an up to date Speed Test the next time the slow down occurs?
You'll need to run the "Further Diagnostics" once the first test completes. Once you have run the test, please post back the results and I'll chase this with Wholesale.
PaddyB
Message 15 of 23
@PaddyB Further diagnostic results taken as seen below. An error also occurered regarding additional details etc.
Message 16 of 23
@RobbieMac
I did a wired speedtest using a laptop but when it gets to the further diagnostic, it says an error occurred when trying to get further information.
The test was showing 3.8 down and 6 5 up.
Moderator
Moderator
Message 17 of 23
@Tolla Thanks for posting, I can see @RobbieMac has is due to get back to you tomorrow with an update. The speed test can be temperamental and would be worth trying again this evening if possible? The further diagnostics part of the test records on Wholesales system and it will help Robbie to provide evidence to the network team of the problem.
Message 18 of 23
@NeilO @RobbieMac
Yes, I will try again this evening . I kept getting an error on the further details part of the test and tried multiple times.
Moderator
Moderator
Message 19 of 23
@Tolla Thanks. @RobbieMac will be in touch tomorrow.
Message 20 of 23
@NeilO @RobbieMac
Tried a wired speedtest this evening and every time on the further diagnostic part, I got  "an error occurred while trying to retrieve additional details regarding your service"
I ran the test at least 10 times.
I got 4.06 mb down and 7.59 mb up on the last try.
Please see screen shot below.
