imjolly
Message 11 of 15
Re: Infinity 2 speed
your connection speed is just above the handback speed  are you using the test socket or the master socket or an extension socket?  best connection should be test socket with a filter
Tomryan
Message 12 of 15
If this is how its going to be, then i'd rather switch to Infinity 1 and save myself a tenner a month. I wasnt even getting the 20 upload either.
Tomryan
Message 13 of 15
i am using the test socket with the supplied micro filter
imjolly
Message 14 of 15
I would get engineer visit as your speed is lower than estimate and if engineer cannot get better speed then downgrade to infinity 1
Tomryan
Message 15 of 15
so, after being on thephone for over an hour, i have an engineer booked for the 20th. Maybe something will get sorted, maybe not
