baz2963
Message 1 of 8
Infinity 2 speeds as 1 ??
Hi all,
I had the services installed yesterday, I plumped for Inifinty 2.
Now the speeds I am getting (after numerous tests) are solid, but the speeds of infinity 1. If I cant achieve more than this I may as well pay for Infinity 1.
The BTW (further diag) performance test throw up the below.. please can someone advise/help.  Thanks !Smiley Happy
 Download speedachieved during the test was - 39.03 Mbps
 For your connection, the acceptable range of speedsis 32.19 Mbps-40.24 Mbps .
 Additional Information:
 IP Profile for your line is - 40.24 Mbps
Upload speed achieved during the test was - 6.48Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
7 REPLIES 7
clairelouise2
Message 2 of 8
Re: Infinity 2 speeds as 1 ??
what is the speed you get quoted here? http://www.dslchecker.bt.com/
baz2963
Message 3 of 8
Clean 38.1 29.9 7.8 6.1 -- Available
Impacted 31.2 16.4 7.8 4.7 -- Available
clairelouise2
Message 4 of 8
from that then no.. you won't be able to get higher than infinity 1 speeds.
baz2963
Message 5 of 8
Cool, thanks. I'll change my subscription then.
baz2963
Message 6 of 8
Got to start this up again ... speeds are really low now and its consistently low. I havent change anything ... ???!!
1. Best Effort Test: -provides background information.
Download Speed
15.61 Mbps
0 Mbps 33.78 Mbps
Max Achievable Speed
Download speedachieved during the test was - 15.61 Mbps
For your connection, the acceptable range of speedsis 27.02 Mbps-33.78 Mbps .
IP Profile for your line is - 33.78 Mbps
2. Upstream Test: -provides background information.
Upload Speed
5.84 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 5.84Mbps
The test result has indicated that you should contact your ISP for further assistance.
Deathtrap3000
Recognised Expert
Message 7 of 8
Were the tests made over wifi or using a cable? With an ip profile like that you should be getting  about 30mbps.
baz2963
Message 8 of 8
They were made over cable :0(
