xenxshaman
Message 1 of 15
Infinity 2 upgrade but IP Profile appears to be stuck
Hi there, wondering if anyone can help, i first got bt infinity 2 years ago when i moved into the house im in now, for a year or so i got around 45-48ish mbits down and about 6 up, then middle of last year the speed dropped to about 29 mbits down, but up stayed at 6.
I rang bt about 5 or 6 times and went through all of the procedure for checking everything my end and eventually they agreed with what i thought that the ip profile had gone mad and needed to be reset, it had dropped to 29mbits which my speed seemed to hit all the time. Anyway they said they would reset it and never did, then after several more phone calls and promises to reset it and more speed tests and router rebooting and etc teci just gave up and figured what the hell 29 is fine (it became way to much hard work to deal with the call centre and not once did my ip profile even budge an inch so i doubt it was ever changed)
anyway fast forward to now, and iv just upgraded to btinfinity 2, but the ip profile on my line hasnt changed, its still firmly stuck at the same 29.3 mbits its been stuck atfor a year, and my download speed is exactly, 29.3mbits lol
should an upgrade to btinfinity 2 not reset the ip profile and begin a new 10 day cooldown period? because it doesnt seem to have and my line seems to be clearly capable of more, as its hitting that cap consistantly every time i test it..
anyway here is the performance diagnostics, if anyone can help id appreciate it
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
 Download Speed
 29.3 Mbps
0 Mbps29.36 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 29.3 Mbps
 For your connection, the acceptable range of speedsis 20.55 Mbps-29.36 Mbps .
 Additional Information:
 IP Profile for your line is - 29.36 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 5.76 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 5.76Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
14 REPLIES 14
Message 2 of 15
Re: Infinity 2 upgrade but IP Profile appears to be stuck
All an upgrade to Infinity 2 fom Infinity 1 does is remove a software cap on the line. It does not reset anything. If your line was faulty before the upgrade it will still be faulty after it.
Can you run this checker and post back a screen shot of the results
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
If you have a Homehub 5 can you also post the stats from 1-12 by logging onto the homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
xenxshaman
Message 3 of 15
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date  High Low High Low
FTTC Range A (Clean)6547.919.112.6--Available
FTTC Range B (Impacted)55.431.819.18.6--Available
WBC ADSL 2+Up to 6.5--5.5 to 7.5Available
WBC ADSL 2+ Annex MUp to 6.5Up to 15.5 to 7.5Available
ADSL MaxUp to 6--5 to 7Available
WBC Fixed Rate2----Available
Other Offerings
Fibre Multicast------Available
Copper Multicast------Available
i dont have the new homehub im still using the previous one and the white openreach modem
Message 4 of 15
Obviously depending on what Range of line you have you should be getting speeds between 32Mbps and 65Mbps. Your present speeds are out side that. You need to call BT and report a fault and request an engineer out to investigate.
They will go through all the usual checks etc. Stick with it and play their game but do not be fobbed off with a ten day training period or that they will do a reset.
Only an engineer can do a reset and it is pointless if they do not find the underlying cause of the speed drop. All that will happen is the problem will return
xenxshaman
Message 5 of 15
thanks ill try 🙂
xenxshaman
Message 6 of 15
they said theres a network fault and they will pass it to the faults team and ring me back 😞 exactly what happened last time, i already know whats going to happen,
Them: hi there weve fixed the fault can you check your speed now?
Me: its still 29.3 mbits and the ip profile hasnt changed
Them: ok we will look into it and call you back
(48hrs later)
The hi there weve fixed the fault can you check your speed now?
Me: Yes its still 29.3mbits the ip profile needs to be reset and it still hasnt been
Them: ok we'll pass it to the correct team and call you back 🙂
(48hrs later)
Them: hello there weve found a fault on your line and it should have been fixed can you check the speed now?
Me: Yes its still 29.3mbits the same as always
Them: can you reset the modem
Me: yes iv reset the modem its still 29.3 mbits
Them: ok hold on we will do some line checks
Them: ok there is a fault on your line we will try to fix it and ring you back
Me: ---- Head--- Desk--- Give up 😛
i know that wasnt relevant but i enjoyed writing it lol
Distinguished Guru
Message 7 of 15
Oh sorry, I see you don't have a HH5. What sort of white modem do you have?
If not, I'll try again 🙂
xenxshaman
Message 8 of 15
iv got the bt openreach one and the HH3, got it when infinity 1 was installed
xenxshaman
Message 9 of 15
i knoew they wont fix it they went through all this before, they just go on and on about some fault on the line for weeks and ignore everything i say about the ip profile until i give up the will to live 😞
Distinguished Guru
Message 10 of 15
What make is the white modem - Huawei or ECI ?
I think there's a label on the underside
