R134rd0
Message 11 of 24
Re: Infinity 2 - viscous circle between openreach and BT
I can do but will that not just send another open reach engineer?
Checked the line, no noise at all...?
imjolly
Message 12 of 24
yes it would probably result in another engineer and hopefully get what you consider the fault fixed.  either that or you just sit until it gets worse and get engineer then but if they cannot find a fault then there is nothing they can fix
R134rd0
Message 13 of 24
I think that's where I've got to now, no one can categorically say what's wrong as none of the test equipment indicates a fault but the engineers can see that it's not right either...
I'd rather not wait until its completely unusable before they scramble into action?
For the cost of the engineers that have been out so far I'm assuming it would have been cheaper to swap the cable as its the only unknown variable left...
pippincp
Sage
Message 14 of 24
I think you need mod help with this one. They may send an engineer again but will check his report to see what further action is required.
NeilO
Moderator
Moderator
Message 15 of 24
@R134rd0 Please use the 'click here to contact the mods' link in my forum profile to send in your details and we'll be happy to help. You can find the link by clicking on my username.
Neil
R134rd0
Message 16 of 24
Ok will do that now...
R134rd0
Message 17 of 24
Today is a special occasion as it marks the beginning of month 4 🙂
pippincp
Sage
Message 18 of 24
Hopefully it will be resolved soon.
R134rd0
Message 19 of 24
@NeilO Thanks for your call at the weekend, just to confirm the visit tomorrow is good for me.
NeilO
Moderator
Moderator
Message 20 of 24
@R134rd0 Good stuff, I'll follow up with you tomorrow.  Smiley Happy
