stretford35
Newbie
Message 1 of 4
Infinity 3 Connecton & Speed issues
Morning all,
I'm experiencing intermittent connection issues and a massive speed drop on my infinity 3 service; I have FTTP and usually achieve between 200 & 220mbps.
Interestingly my BT Smart Hub won't even connect to the service but its not a road to house issue as my ASUS RT-AC87U does connect although with very limited throughput.
Please see speed test results & router config below; any guidance from the Mods would be greatly received
3 REPLIES 3
Message 2 of 4
Re: Infinity 3 Connecton & Speed issues
Have you tried powering down the ONT?
stretford35
Newbie
Message 3 of 4
Hi ya & thanks for the quick reply; excuse my ignorance, is the ONT the modem (attached the wall?)
I did pull the power but I don't think the modem actually powered off, there seems to be an internal battery which keeps the LAN light solid green
I'll try again though
cheers
stretford35
Newbie
Message 4 of 4
Hi Ya,
I've rebooted the modem, results are below. I've also tried running the additional diagnostics test which comes back with the following message
"Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information."
Result following reboot & diagnostics message below and I've also added the results from http://dslchecker.bt.com for comparison.
Do you think its looking like an engineer visit is needed?
