MarkACE
Message 1 of 9
Infinity 80Meg service - BT speed tester results show max available 80 but only getting 40.
I am confused when I use the ADSL and fibre to the cabinet it reports a connection of only 40 but that the line is set up for 80. Is this the wrong option? I still have a drop wire so pretty sure fibre to the premises isn't the right option. When I use the beta over 24meg this appears to report 75/6 which feels more accurate.
Have a missed something?
Thanks in advance for your help:smileyvery-happy:
8 REPLIES 8
Nige32
Message 2 of 9
Re: Infinity 80Meg service - BT speed tester results show max available 80 but only getting 40.
Hi
     BT speed tester can be a bit hit and miss at the minute.
Try www.speedtester.net or www.speedtester.bbmax.co.uk   and see what speed they give you.
Edit: Also it can take a while for the BT speedtest update the correct ip profile after the upgrade to the fastest speed.
Paul1360
Expert
Message 3 of 9
That's for sure BT Speed tester is hit or miss, I've just had my result from for a very long time and my D/L speed was 4Mb on IP profile of 77.43Mb and U/L of 16.36Mb profile of 20Mb, really pleased with my D/L speed as it's a lot better than 0 or .89 lol.
iechyd da
Distinguished Guru
Message 4 of 9
iechyd da
To be honest, I think it's more miss than hit.
toekneem
(EASBF)
deano3693
Message 5 of 9
Agreed with Toekneem 🙂 Defo miss most of the time !!
IT SUPPORT TECHNICIAN - Comptia A+ Certified, MTA Qualified and MTSC qualified
Paul1360
Expert
Message 6 of 9
That's very true "MISS" , it's getting better now I've got 8Mb D/L lol on the Beta 76.45Mb, How can BT get is so right and yet so wrong lol
I only use them as a snap shot nothing else as I'm lucky I can look at at my connection on an hour by hour basis which is a lot more accurate.
iechyd da
Flashpaul
Message 7 of 9
I am finding that speedtest.net is also giving erratic results , most of the servers show less than 40Mb/s for me.
I reckon that speedtest.net is overloaded with all the new upgraded infinity customers !
I get much more consistent [higher] speeds from these sites :-
speedtest.bbmax.co.uk
vmspeed.com
http://speedtest.magnet.ie/
I can download files at about 8.5MB/s and the 3 sites above are in line with this.
deano3693
Message 8 of 9
Agreed with Flashpaul. I dont rate the BT speedtester or speedtest.net as these are in such high demand due to the surge of BT customers who have upgraded there broadband to run 50 speedtests a day 🙂
MarkACE
Message 9 of 9
:robotlol: Thanks all for your help
