jevanbh1
Message 1 of 7
Infinity Avalibility
Hello, I have joined specifically to ask about the avaliability of Infinity.
My exchange is Slough Main and it is said to be enabled on SamKnows and by BT themselves. However, I am not able to get Infinity. Infinity would benefit me greatly as I only get a maximum of 1Mbps on a good day.
I realise that the street cabinet has to be upgraded; is there any way of requesting this or finding out when this will happen? The Cabinet I'm connected to is number 49 for your information.
6 REPLIES 6
Message 2 of 7
Re: Infinity Avalibility
According to the December OR spreadsheet that escaped into the "wild" Slough Main (THSL) P49 is due to be upgraded in phase 9b which is as far as I know likely to be late 2012. It is predicting a 5.42 uplift in speed ie if you currently get 1Mb/s you should get 5.42 Mb/s on FTTC.
BT currently will not supply Infinity unless the estimate is 15Mb/s but there is a slower fibre product sold under the Total Broadband brand but  that has a minimum cut off of 5Mb/s so it will be close if 1Mb/s is your real "predicted" speed for ADSL. You must live a long way from the cabinet (over 2 miles) or have serious issues with your line.
Guru
Message 3 of 7
So is the download for Infinity calculated by your current connection times by the uplift?
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
Message 4 of 7
I think the estimate is the estimated ADSL 2 speed times the uplift - this checks out on my own connection. I like many others get a faster connection so I get 40Mb/s against the 33Mb/s forecast.
All changes this weekend when they recalculate the estimated speeds to take account of the new 17a profile. I assume a "new" spreadsheet will show revised uplift figures at some point.
Guru
Message 5 of 7
ah ok, because my current ADSL 2 speed against the forecaste would bring it over 40mb roundabouts anyways, but yea it's going to be very interesting to see what the new 80/20 meg speeds are this weekend.
jevanbh1
Message 6 of 7
Thanks for the reply, is there any more details on this slower fibre product you mentioned? It would benefit me given my location to Slough Main. Im almost 3 miles from the exchange and almost a mile from the cabinet
Guru
Message 7 of 7
Just put your number into the checker here - www.bt.com/infinity and it should give you your estimations for your line.
