chookie75
Message 1 of 3
Infinity Connection Issues
Hi,
Can anyone help please? I am unable to connect to broadband at present.
The HH lights are blue. The Open Reach Modem is fine too.
HH Event log states the following
Time and date
Message
08:15:35, 03 Nov.
( 1276.390000) CWMP: session closed due to error: Could not resolve host
08:15:20, 03 Nov.
( 1261.370000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
08:15:20, 03 Nov.
( 1261.370000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE'
08:14:50, 03 Nov.
( 1231.070000) CWMP: session closed due to error: Could not resolve host
08:14:33, 03 Nov.
BLOCKED 21 more packets (because of Default policy)
08:14:33, 03 Nov.
OUT: BLOCK [15] Default policy (UDP 192.168.1.78:32769->213.123.22.197:5803 on ppp1)
08:14:33, 03 Nov.
( 1214.120000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
08:14:33, 03 Nov.
( 1214.120000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE'
08:14:31, 03 Nov.
( 1212.510000) WAN operating mode is Ethernet
08:14:31, 03 Nov.
( 1212.510000) Last WAN operating mode was Ethernet
08:14:31, 03 Nov.
( 1212.480000) PPPoE is up
08:14:31, 03 Nov.
( 1211.850000) PPP IPCP Receive Configuration ACK
08:14:31, 03 Nov.
( 1211.820000) PPP IPCP Send Configuration Request
08:14:31, 03 Nov.
( 1211.820000) PPP IPCP Receive Configuration NAK
08:14:31, 03 Nov.
( 1211.790000) PPP IPCP Send Configuration ACK
08:14:31, 03 Nov.
( 1211.790000) PPP IPCP Receive Configuration Request
08:14:31, 03 Nov.
( 1211.790000) PPP IPCP Send Configuration Request
08:14:31, 03 Nov.
( 1211.790000) CHAP authentication successful
08:14:31, 03 Nov.
( 1211.560000) CHAP Receive Challenge
08:14:31, 03 Nov.
( 1211.560000) Starting CHAP authentication with peer
08:14:31, 03 Nov.
( 1211.560000) PPP LCP Receive Configuration ACK
08:14:30, 03 Nov.
( 1211.530000) PPP LCP Send Configuration Request
08:14:30, 03 Nov.
( 1211.530000) PPP LCP Receive Configuration Reject
08:14:30, 03 Nov.
( 1211.500000) PPP LCP Send Configuration ACK
08:14:30, 03 Nov.
( 1211.500000) PPP LCP Receive Configuration Request
08:14:30, 03 Nov.
( 1211.500000) PPP LCP Send Configuration Request
08:14:20, 03 Nov.
( 1201.340000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
Any ideas would be much appriciated
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: Infinity Connection Issues
Try this:
Make a direct connection from your PC to the modem which will eliminate the homehub. Follow this guide to do that. Use your computer as normal and run a speed test. If it improves you will know its a fault after the modem that could be the hub or your cables.
Step 1: Remove the homehub from the modem
Step2: Connect your pc/laptop into the modem using LAN1 port
Step3: Open network and sharing centre on windows and click set up a new connection or network
Step4: Connect to the internet then click make a new connection Broadband PPPoE
Step5: Use username of bthomehub@btbroadband.com and password of BT
Step6: connect, If it doesn't,keep pressing try again until it does.
If not, I'll try again 🙂
chookie75
Message 3 of 3
Thanks for the advice
I tried below and got a result (Only 7Mb/s but at least it's something)
I then attached my old HH and it seems to be working now!
Just need to sort the speed out now!
