plainview
Recognised Expert
Message 11 of 21
Re: Infinity Data Extension installation
'16mm bit for a bit of Cat5?'
Yes, the 16mm wood dril bit Openreach Engineers are issued is the same width, well obviously a little bit wider so we can easily push through a 2, 3 pair Cat5e or 4 wire through the hole.
That's 16mm long, not wide. The width is about 5mm.
Steve2070
Message 12 of 21
"That's 16mm long, not wide."
OK but 16mm in length ain't going to get you though a door frame?
plainview
Recognised Expert
Message 13 of 21
'OK but 16mm in length ain't going to get you though a door frame?'
Oh yeah, tell that to the two door frames I drilled through yesterday and the one I drilled through last week.
Trust me mate, I do FTTC Provisions for a living for a well known company that starts with a 'O' and ends with a 'H' Can't tell you the full name of the company as it upsets the resident Call Centre Workers but I'm sure you can guess which one it is.
Distinguished Guru
Message 14 of 21
16mm is about half-an-inch
If not, I'll try again 🙂
plainview
Recognised Expert
Message 15 of 21
The zero key on my keyboard isn't working, sorry should have mentioned that in my original post.
Distinguished Guru
Message 16 of 21
lol
Steve2070
Message 17 of 21
Allright calm down fella. I'm in the building trade so I know drill sizes.
I'm guessing you've just quoted the wrong one.
plainview
Recognised Expert
Message 18 of 21
HA HA, I'm only jesting ya. To be honest I meant 160mm, I didn't notice I missed the 0 even when I copied/pasted it. My bad.
Distinguished Guru
Distinguished Guru
Message 19 of 21
Is that company you work for anything to do with BT?Smiley Very Happy
Community Manager
Community Manager
Message 20 of 21
Hi plainview,
Can you PM me an email address for you or send us an email via our Contact us form (on my profile page)? We've been trying to get in touch but the email address associated with your forum profile doesn't work any more.
Thanks,
Stephanie
Community ModeratorStephanie
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
