theotherjamie
Message 1 of 13
Infinity IP Profile 1.93Mbps!
For the past few weeks I've been suffering from slow internet speeds but put this down to using homeplugs. I finally got round to moving the PC next to the homehub to run a speedtest and got the below results
1. Best Effort Test:  -provides background information.
 Download speedachieved during the test was - 2.19 Mbps
 For your connection, the acceptable range of speeds is 16 Mbps-0 Mbps.
 IP Profile for your line is - 1.93 Mbps
2. Upstream Test:  -provides background information.
Upload speed achieved during the test was - 4.59Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 20 Mbps
This has now been the case for the past three nights with the IP Profile always at 1.93 and the download around 2Mbps!!!
Any suggestions as I'm becoming increasingly frustrated at paying twice the price for Infinity and getting half the speed of my previous ISP?
12 REPLIES 12
Distinguished Guru
Message 2 of 13
Re: Infinity IP Profile 1.93Mbps!
Is the PC wired to the hub or wireless?
Actually it doesn't matter, its the IP profile and the speedtest should advise you to call the ISP 🙂
If not, I'll try again 🙂
theotherjamie
Message 3 of 13
wired - 0.5m cat5e patch lead
astar27
Expert
Message 4 of 13
Well, it's certainly not a wireless issue ray_dorset. Basically, explain what you've tried so far? Have you tried restarting both, Home Hub and Openreach modem?
Distinguished Guru
Message 5 of 13
The poster says its a wired connection
theotherjamie
Message 6 of 13
yes tried restarting both.
Also tried different patch leads and different ports on the homehub.
astar27
Expert
Message 7 of 13
Reset the Openreach modem?
theotherjamie
Message 8 of 13
yes the openreach modem and the homehub
Locky
Expert
Message 9 of 13
As above, restart the Hub/router and the modem, switch them off for 5 minuets.
theotherjamie
Message 10 of 13
I've done this numerous times and it makes no difference.
The below result is from a minute before this post after powering down the openreach modem and the homehub for 5 minutes.
 Download speedachieved during the test was - 2.16 Mbps
