CWD
Message 1 of 3
Infinity Install: Master Socket Swap to Quadruplex Slave Socket
My apologies if this has been answered already. I have searched the forum already, and whilst I could find posts around swapping master and slave sockets, I couldn't find anything specifically about my situation:
I'm currently scheduled to have Infinity installed on the 31st of March. My master socket is currently located in my main entrance hall near the front door. The hall is very narrow and really not an ideal location to be having a modem and router:
Master
I've currently got my ADSL modem and router plugged into a slave socket upstairs, so ideally I'd like the engineer to swap the sockets at the time of installation. However; the slave socket I'd like to use instead is some sort of weird quadruplex jobbie that does TV and satellite as well:
Slave
So my question is; will the BT engineer be able to swap these sockets around in some way or fashion? Or am I stuck with having the modem plugged in downstairs? 😞
Thank-you in advance for your replies.
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: Infinity Install: Master Socket Swap to Quadruplex Slave Socket
Hi CWD,
Welcome and thanks for posting. Moving the socket would be down to the engineer. It doesn't look like a standard BT socket so maybe a cuppa and a few bikkies for the engineer might help. Smiley Wink
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
CWD
Message 3 of 3
Just to follow this up; the engineer was very accommodating and installed a new master socket next to the weird duplex thing I showed above. He then disconnected my old master and everything is now good! 🙂
