nesetceri
Message 1 of 3
Infinity Instillation
A few years ago I had BT Infinity with Hub 4. Engineer came inside my house, fitted a new mains socket and a White box with Power-DSL-Lan1-Lan2 lights flashing. From Lan1terminal   a cable fits to Broadband WAN terminal on my BT Hub 4. However watching the Infinity Instillation video  with Hub 5,  it is self instillation and the broadband cable fits to Hub 5 DSL terminal ( just like self installing non infinity to Hub 4) An explanation will be appriciated Thanks
2 REPLIES 2
Message 2 of 3
Re: Infinity Instillation
You do not need the white Openreach modem.
The home hub 5 comes with an RJ11 lead and plug, which plugs into the same place as the white Openreach modem. You simply unplug and turn off the modem.
Old arrangement
Home hub 4 with modem
New arrangement
Home hub 5 connection
Message 3 of 3
Do not discard the openreach modem as many still prefer that to the all in one modem/router
