mike63uk
Message 1 of 9
Infinity Speed Drop
I have had Infinity for 2 years 9 months and all has been fine until 08:07 on the 26th November.
Up until then I was syncing at 77 and getting an IP profile of 73, now the sync speed has dropped to 64.59 with an IP Profile of 64.97 for no apparant reason.
I am on the BT homehub 5 and its connected directly to the master socket.
I live aprox 200 meters from the street cabinet.
I have a SamKnows white box which backs up the speed I have been receiving.
Regards
Michael Gibson
Connection Information
Line state:Connected
Connection time:0 days, 00:04:55
Downstream:64.59 Mbps
Upstream:19.53 Mbps
1. Product name:BT Home Hub
2. Serial number:+068343+NQ34418865
3. Firmware version:Software version 4.7.5.1.83.8.173.1.6 (Type A) Last updated 24/04/14
4. Board version:BT Hub 5A
5. VDSL uptime:0 days, 00:05:19
6. Data rate:20000 / 66140
7. Maximum data rate:26980 / 76385
8. Noise margin:9.5 / 6.6
9. Line attenuation:0.0 / 14.4
10. Signal attenuation:0.0 / 14.4
11. Data sent/received:0.2 MB / 1.2 MB
12. Broadband username:bthomehub@btbroadband.com
8 REPLIES 8
Message 2 of 9
Re: Infinity Speed Drop
connection time is only 5min is that due to manual reset or router dropping connection?
mike63uk
Message 3 of 9
I rebooted the router to see if the speed would increase.
nomad2k3
Message 4 of 9
Done the same with me, gone from 76mb to 69mb and 20mb to 19mb up.
BT up to their old tricks as usual, slowing down connections.
Message 5 of 9
BT Retaill do not control the network Anymore than SKY or TT however the more customers on your cabinet the more likely your speed is likely to reduce and especially noticeable if you were in first batch to get fibre
Distinguished Guru
Message 6 of 9
BT Retail control the modem remotely. What do these lines mean?
12:02:29, 10 Dec. (432648.830000) CWMP: session completed successfully
12:02:29, 10 Dec. (432648.540000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
12:02:26, 10 Dec. (432645.360000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
12:02:26, 10 Dec. (432645.350000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
12:02:25, 10 Dec. (432645.040000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
What value has been changed, and why?
If not, I'll try again 🙂
mike63uk
Message 7 of 9
This should not affect the sync speed or IP Profile to the cabinet as this should depend upon the quality and length of the copper pair and not the number of connections in the cabinet.  Anyway this would not explain a sudden drop of 9Mbps at 08:07 in the morning.
dfenceman
Expert
Message 8 of 9
You may find this of interest :- http://www.increasebroadbandspeed.co.uk/2014/vectoring-crosstalk-crisis
As it explains the number, and more importantly the proximity of other pairs, will affect speeds regardless of line quality.
I agreee that it is unlikely to be the cause of a speed drop at such a precise time, unless of course and engineer connected some new lines at that time.  So there could well be other issues.
Please enter your telephone number into http://www.dslchecker.bt.com/adsl/adslchecker.welc​ome  and post the results, after first removing your telephone number.
Best regards,
dfenceman
mike63uk
Message 9 of 9
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date  High Low High Low
FTTC Range A (Clean)8066.62020--Available
FTTC Range B (Impacted)8054.32017.7--Available
WBC ADSL 2+Up to 25--22 to 28.5Available
WBC ADSL 2+ Annex MUp to 25Up to 122 to 28.5Available
ADSL MaxUp to 8--7 to 8Available
WBC Fixed Rate2 ----Available
Other Offerings
Fibre Multicast------Available
Copper Multicast------Available
