Bimmerlad
Message 1 of 2
Infinity Speed Test Results Day 1
Finally had my infinity activated in my new home today! Great, apart from speedtest.net results have got progressively worse as the day progressed. BT engineer tested it and I got >30mb on average from first 3 tests...now down to just 1mb tonight 😞
I know it says during first 10 days speed results fluctuate due to line testing, but 30mb down to 1mb...really? I don't remember such a massive variance last time I had infinity installed at my old home.
Is this normal or does this suggest there is a problem with the infinity install?
(Only done more speed tests because using the net all afternoon it was getting slow again...)
1 REPLY 1
Guru
Message 2 of 2
Re: Infinity Speed Test Results Day 1
There has been problems with some peoples Infiny using a fibrelink on retail servers, you may be affected and is meant to get fixed tomorrow or the day after. I think you will find it raise tomorrow then go down at night time again unless it has been fixed.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
