imjolly
Message 11 of 15
Re: Infinity Speed dropping
connection time is only 9hrs  was that router dropping connection or manual reset  needs at least 14 days stable for DLM to take action and maybe even more
roco1970
Message 12 of 15
Hi
I restarted the router as i need to unplug the multi plug. It has been connected for around 9 weeks since the fault was fixed by open reach but the line seems to be stuck at that sync speed. Open reach did say they would reset the line but never did.
Matt-S
Moderator-Retired
Message 13 of 15
Hi @roco1970,
Welcome back to the Community.
I've sent you a Private Message with details on how you can get in contact with the mod team so that we can take a look into this for you.
Matt
roco1970
Message 14 of 15
Hi Matt my speed has returned to normal thanks so much to to all involved.
NeilO
Moderator
Moderator
Message 15 of 15
Hi @roco1970, Brilliant I'm glad that's sorted for you. I'll make sure to pass on your thanks to @StuartH as he helped you with this.
