AS2856
Message 1 of 13
Infinity Speed seems to be quite low
Hi All,
  I am getting slower than expected infinity2 speeds on my line. I did recently fix an internal cabling issue that i believe was dragging it down but it does not seem to want to go up despite fixing it.
I have a Draytek Vigor 130 connected to my own router but the line specs are as follows from the Draytek:-
First - the stats prior to the cabling issue:-
Vigor> vdsl status
  ---------------------- ATU-R Info (hw: annex A, f/w: annex A/B/C) -----------
   Running Mode            :      17A       State                : SHOWTIME
   DS Actual Rate          : 43996000 bps   US Actual Rate       : 20000000 bps
   DS Attainable Rate      : 52986120 bps   US Attainable Rate   : 20048329 bps
   DS Path Mode            :  Interleave    US Path Mode         :        Fast
   DS Interleave Depth     :      688       US Interleave Depth  :        1
   NE Current Attenuation  :       18 dB    Cur SNR Margin       :        6  dB
   DS actual PSD           :     6. 6 dB    US actual PSD        :    13. 6  dB
   NE CRC Count            :        0       FE CRC Count         :     2683
   NE ES Count             :        0       FE  ES Count         :     2127
   Xdsl Reset Times        :        0       Xdsl Link  Times     :        1
   ITU Version[0]          : b5004946       ITU Version[1]       : 544e0000
   VDSL Firmware Version   : 05-07-06-0D-01-07   [with Vectoring support]
   Power Management Mode   : DSL_G997_PMS_L0
   Test Mode               : DISABLE
  -------------------------------- ATU-C Info ---------------------------------
   Far Current Attenuation :       23 dB    Far SNR Margin       :        6  dB
   CO ITU Version[0]       : b5004946       CO ITU Version[1]    : 544ed086
   DSLAM CHIPSET VENDOR    : < IFTN >
And after it was fixed, the DS Attainable Rate has went up quite a bit:-
Vigor> vdsl status
   DS Actual Rate          : 44000000 bps   US Actual Rate       : 20000000 bps
   DS Attainable Rate      : 71662872 bps   US Attainable Rate   : 27363767 bps
   DS Interleave Depth     :      912       US Interleave Depth  :        1
   NE Current Attenuation  :       14 dB    Cur SNR Margin       :       10  dB
   DS actual PSD           :     5. 1 dB    US actual PSD        :    13. 5  dB
   Xdsl Reset Times        :        0       Xdsl Link  Times     :        2
   Test Mode               : DISABLE
   Far Current Attenuation :       18 dB    Far SNR Margin       :        9  dB
It seems to want to sit at bang on 44000000 bps for downstream which to me seems to feel quite low and like some sort of imposed limit.
Is there anything i can do here?
12 REPLIES 12
imjolly
Message 2 of 13
Re: Infinity Speed seems to be quite low
the fix in cabling has obviously improved your connection in that your attainable is now 71mb and previously 52mb.  however all the problems with your conenction probably dropping and the resets when you were fixing the cabling has resulted in you ending up in a banded profile  this should release automatically but needs a stable connection and could take weeks rather than days
your current stats don't show internet conenction time
AS2856
Message 3 of 13
Thanks Reverend, have you fixed that pilot light yet?
Although i have a confession to make, i work in networks and am always tampering with kit and my connection probably goes down more than most as i flip things, reconfigure stuff etc.
Does that affect it? Would myself powering it up / down and/or bringing the PPPOE connection up / down affect the line speed or is it based more on line counters like noise / attenuation etc.
Finally, is there any way the process of a resyncing the speed can be sped up? Or do i need to keep my modem up and on and running constanly for a few weeks?
imjolly
Message 4 of 13
all your tinkering with the connection and the powering off/on and just resetting modem are seen as line problems with DLM and that has resulted in the banded profile  https://community.plus.net/t5/Library/FTTC-DLM-What-it-is-How-it-works/ba-p/1322799
you now need stable connection 24/7 - no resets - for DLM to relent and remove banding
AS2856
Message 5 of 13
Hi,
  Futher to this - i've just noticed that the DS Actual rate has shot up overnight to 60mbps...
Vigor> vdsl status
   DS Actual Rate          : 60000000 bps   US Actual Rate       : 20000000 bps
   DS Attainable Rate      : 70785400 bps   US Attainable Rate   : 27376720 bps
   DS Interleave Depth     :      899       US Interleave Depth  :        1
   NE Current Attenuation  :       14 dB    Cur SNR Margin       :        6  dB
   DS actual PSD           :     5. 0 dB    US actual PSD        :    13. 7  dB
   NE CRC Count            :        0       FE CRC Count         :     2689
   NE ES Count             :        0       FE  ES Count         :     2133
   Xdsl Reset Times        :        0       Xdsl Link  Times     :        3
   Test Mode               : DISABLE
However, i still get only 40mbps when downloading, which is basically the same as yesterday - and thats testing directly from my router, although PC's give the same result.
Should i now be getting closer to 60mbps here?
Also, i notice that G.INP isnt enabled at the far end...
Vigor> vdsl status more
                  Near End        Far End    Note
 Trellis      :      1               1
 Bitswap      :      0               1
 ReTxEnable   :      0               0
(ReTxEnable set to 0 indicated that) - is that normal?
Thanks also for taking the time to answer above.
imjolly
Message 6 of 13
you can try running btspeedtester and the diagnostic test and post results but this has given some odd results and is a known problem  you can also try speedtest.net and see what download speed you can get now conenction speed increased to 60mb
AS2856
Message 7 of 13
[2.4.3-RELEASE][admin@pfsense.xxxxxxxx.co.uk]/root: speedtest-cli
Retrieving speedtest.net configuration...
Testing from BT (x.x.x.x)...
Retrieving speedtest.net server list...
Selecting best server based on ping...
Hosted by ITPS Ltd (Newcastle Upon Tyne) [177.25 km]: 109.724 ms
Testing download speed................................................................................
Download: 40.32 Mbit/s
Testing upload speed................................................................................................
Upload: 18.73 Mbit/s
Thats directly from the router cli.
My BTSpeedtest results are slightly slower...
Download Speed(Mbps): 36.52 Mbps
Upload Speed(Mbps) : 21.07 Mbps
Ping Latency(ms): 39 ms
imjolly
Message 8 of 13
as I said btspeedtester gives odd results - your upload speed is faster than your conenction speed!!!
are you connected directly with ethernet cable from router to your pc - no powerline adapters
AS2856
Message 9 of 13
Hi,
  If you look above you'll see that one set of stats i gave were ran directly from the router itself, which is only connected to the modem via an ethernet cable.
I have however now powered off the Draytek - left it for 30min and then powered it back on again.
Running the same test again i get:-
[2.4.3-RELEASE][admin@pfsense.xxxxxxx]/root: speedtest-cli
Testing from BT (xxxxxx)...
Hosted by ITPS Ltd (Newcastle Upon Tyne) [177.25 km]: 30.452 ms
Download: 54.87 Mbit/s
Upload: 18.38 Mbit/s
Which seems much better. I just hope DLM doesnt punish me tonight for a poweroff then poweron half an hour later.
I'll keep an eye on th espeeds over the next few days.
imjolly
Message 10 of 13
These figures look a lot better
if DLM was going to take any action it would have happened when you re-connected so as long as stable will be fine
