pippincp
Sage
Message 11 of 13
Re: Infinity Speed seems to be quite low
Re- G.INP now that DLM has relented and your noise margin has dropped to 6.0dB it will take about 14 days for G.INP to kick back in.
AS2856
Message 12 of 13
Thanks,
From what i had read, I concluded that G.INP was a replacement / alternative to interleaving, I didn't realise the two could be on the same cabinet. Or maybe i should say that i thought G.INT was either on or not available on a particular cab.
I will see what happens in a couple of weeks.
Also to flow up from imjollys earlier comment regarding DLM. I was of the understanding that DLM changes happened nightly between 3 and 5am after stats have been analysed. Not immediately as has been suggested.
pippincp
Sage
Message 13 of 13
G.INP is only available on Huawei cabs, I presumed you had it previously. If you post your exchange and cab I can look it up for you.
