jparnell82
Message 1 of 10
Infinity below estimated speed
Hello,
I've noticed gfast pods have started popping up in Exmouth so its got me looking at my Infinity speed and what i should be expecting to receive.
Here are the stats from my Smart Hub:
Data rate: 20.00 Mbps / 59.70 Mbps
Maximum data rate: 20690 / 61372
Noise margin: 6.1 dB / 6.3 dB
Line attenuation: 12.7 dB
The welcome email from BT estimates i should be receiving between 66-80Mbps so I'm obviously below this.
I have tried all the usual tests and tricks such as quiet line test, connecting directly to test sockets etc. but it makes no difference
Given i'm under the estimated speed am i able to ask BT to investigate and try and improve things?
9 REPLIES 9
brookheather
Message 2 of 10
Re: Infinity below estimated speed
What's your current handback speed shown here for your phone number:
https://www.dslchecker.bt.com/
Your current speed may have reduced due to increased crosstalk from other lines.
jparnell82
Message 3 of 10
Handback is 60.6 for impacted and 62.8 for clean.
James
jparnell82
Message 4 of 10
Any advice please. Am I in a position for BT to investigate?
Message 5 of 10
Can you connect to test socket with a filter a post the complete hub stats. Advanced settings then technical log information. Before you move the connection what the current dsl uptime?
have you had problems with connection dropping
can you post the full results from the dslchecker   https://www.btwholesale.com/includes/adsl/main.html
Any noise on quiet line test. Dial 17070 option 2 should be silent and best with corded phone
jparnell82
Message 6 of 10
Hi,
Before i moved to the test socket uptime was just over 7 days - this ties in with when i last tested. I am not aware of any issues with the connection dropping. The quiet line test is clear, i can't hear any noise etc.
Here are the stats from the test socket with a filter:
Product name:BT Hub 6A
Firmware version:SG4B1000B540
Firmware updated:30-Mar-2018
Board version:1.0
Gui version:1.64.0
DSL uptime:0 Days, 0 Hours 7 Minutes 17 Seconds
Data rate:20.00 Mbps / 59.70 Mbps
Maximum data rate:20569 / 61245
Noise margin:6.1 dB / 6.3 dB
Line attenuation:12.7 dB
Signal attenuation:VPI / VCI:0/38
Modulation:G_993_2_ANNEX_B
Latency type:Fast Path
Data sent / received:12291 MB Uploaded / 135184 MB Downloaded
Broadband username:bthomehub@btbroadband.com
Here is the info from the dslchecker:
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low        Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date   ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date Left in JumperObserved SpeedsVDSLOther Offerings     Availability Date   Premise environmentStatus
VDSL Range A (Clean)8068.7201962.8Available----
VDSL Range B (Impacted)8067.2201960.6Available----
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 2.5--1 to 4Available--Yes
ADSL MaxUp to 2--1 to 3.5Available----
WBC Fixed Rate1----Available--Yes
Fixed Rate1----Available----
Max Observed Downstream Speed (Mbps)59.7
Max Upstream Observed Speed (Mbps)20
Observed Date2019-01-29
VDSL Multicast------Available----
ADSL Multicast------Available----
Bridge TapN
VRIN
NTEFaceplateN
Last Test Date25-01-2019
Message 7 of 10
Which exchange and cab are you on?
jparnell82
Message 8 of 10
Exmouth cabinet 56
Message 9 of 10
unfortunately you are an ECI cab and at present you will not get any speed benefit from G.INP
jparnell82
Message 10 of 10
Hmmm ok so it sounds like you're putting speed down to crosstalk? I guess there's nothing I can ask BT to do about it?
When g.fast becomes available will this suffer the same issue?
