Hi,
Since yesterday morning my BT Infinity is not working for any outbound web traffic. I am completely stumped:
Ping works (e.g. to 8.8.8.8)
Tracert returns proper routing info (e.g. tracert www.bbc.co.uk)
DNS works (e.g. nslookup www.bbc.co.uk)
Telnet to websites on port 80 and 443 returns the usual blank screen indicating they're connecting
FTP works.
I've gone through SMS support and they're stumped - they've referred it onto "Specialists" who are apparently going to take up to 5 working days to respond.
This affects all devices - wired PC, IPad and WiFi laptop. I've factory-reset the smart hub, enabled and re-disabled parental control and web protect - nothing works.
Does anyone have any ideas? It's like they're filtering out all my outbound web traffic?!
Pete
Solved! Go to Solution.
Welcome to this user forum.
Can you please check that your phone number has not changed, due to perhaps a crossed line?
Dial 17070 and check the number is correct.
Do you have another router or another home hub that you can try?
Hi,
The phone number is reporting as correct. I've just purchased an ASUS DSL router and this is doing the same - connection reporting as ok, but virtually no web traffic flowing.
I say "virtually", because the Amazon website does seem to be loading on my PC, but very slowly. No other sites seem to be loading.
As before, ping, DNS, tracert all work fine - from the PC and from the router admin.
Any ideas?
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
Hi @JimFraggle sorry that although your broadband shows connected you are unable to use the internet. I've sent you a Private message explaining how you can contact the forum moderation team and we will help you with this.
Cheers
John
Community Moderator | JohnC | |
Did you get the help you needed? Help others by clicking on ‘Mark as accepted solution’ | Show your appreciation! Click on the star next to a reply to say thanks | Help guide to using the community? Click below |
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You |
Hi @JimFraggle
Thanks for taking my call this morning. Glad to hear this appears to have rectified itself.
Should it reoccur as I mentioned post back and I can take another look at it for you.
Stuart
Community Moderator | StuartH | |
