Timewarp
Message 1 of 20
Infinity disconnects once per day
Every evening the broadband connection drops for around 50 seconds.
Tried the online checker and also the Open Reach number to check noise and everything is fine.
I wrote a script that runs from my Raspberry Pi on ethernet to confirm this wasn't WiFi and to pinpoint the exact times of no connectivity.
Checker says I'll need an engineer visit. Is this true? I use Google WiFi rather than the Home Hub.
Message 2 of 20
Re: Infinity disconnects once per day
can you post any connection stats?
does connection drop about same time every night?
sound more like interference than a line problem
Timewarp
Message 3 of 20
Unfortunately, Google WiFi doesn't give stats AFAIK
Yesterday it was around 8.40pm, today around 9.30pm.
Interference outside of the home?
Message 4 of 20
have you tried using the test socket with a filter to eliminate your internal wiring and faceplate from causing a problem - even if you currently use a filtered master socket
difficult to help with some basic connection stats information
Timewarp
Message 5 of 20
I can try that.
I could also plug in my Home Hub 3 to get stats if useful?
My Google WiFi is connected to the Open Reach modem. Is there any interface to this that I can get stats from?
Message 6 of 20
connecting the hh3 wont help as all stats in the modem  if hg612 you can unlock it (try google) but if ECI unlikely as needs to use soldering iron
iniltous
Recognised Expert
Message 7 of 20
Try searching 'REIN' and 'SHINE', unsuppresed electrical equipment switching on and off can cause your broadband to drop out, and especially this time of year when many houses are decorated with Christmas lights , is it possible that someone switching lights off around that time is your problem, it's not neccesarily your own electrical equipment, but could be a neighbour's
Message 8 of 20
https://kitz.co.uk/adsl/rein.htm
Mos Christmas tree lights now use cheap and  switch mode power units, which can cause interference to broadband, but this would normally affect the connection speed.
Communityhelp (Private website) Lots of additional information and help.
You will need to be connected to your home BT Broadband connection to view it, or any links to it that I post on this forum.
Timewarp
Message 9 of 20
Yes, nothing we own would be only going off or on only at those times.
Interestingly, I've only noticed it happen come December. I got cut off a conference call and have noticed alert emails from my dyndns client telling me about a new public IP quite often.
My script confirms the outage is only 50 seconds each time, possibly indicating SHINE?
Timewarp
Message 10 of 20
Tried with a filter, and still disconnects.
Is it possible to get stats from the Open Reach modem? If so, how?
