popshot
Message 1 of 1
Infinity dropping Playstation Network regularly or is it TCP reset attacks?
I got Infinity just over two weeks ago. Speeds are great and reliability on general web use good. It has been regularly (several times per session most sessions) dropping the Playstation network. It usually connects again fairly quickly but it's enough to ruin matters. This happens on two different PS4s and NEVER occurred on Talktalk copper that I was with for years before moving. Can someone please investigate. This is a major issue for me.
Darren
1. Product name:BT Home Hub
2. Serial number:+068343+NQ43508475
3. Firmware version:Software version 4.7.5.1.83.8.204 (Type A) Last updated 21/01/15
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 12:11:50
6. Data rate:6828 / 39992
7. Maximum data rate:6744 / 46729
8. Noise margin:6.0 / 6.2
9. Line attenuation:24.9 / 26.5
10. Signal attenuation:24.9 / 23.9
11. Data sent/received:8.9 GB / 60.1 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
14. 2.4 GHz Wireless network/SSID:BTHub5-7QC7
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:BTHub5-7QC7
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:c8:91:f9:6b:b8:cc
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
Have just also noticed a substantial number of events such as these in the log:
08:55:29, 02 Feb.(1028509.700000) Wire Lan Port 4 down
08:55:27, 02 Feb.(1028507.830000) Device disconnected: Hostname: Xbox-​360-​00-​25-​ae-​85-​0f-​e2 IP: 192.168.1.76 MAC: 00:25:ae:85:0f:e2
08:55:27, 02 Feb.(1028507.820000) Device disconnected: Hostname: Xbox-​360-​00-​25-​ae-​85-​0f-​e2 IP: 192.168.1.76 MAC: 00:25:ae:85:0f:e2
08:55:27, 02 Feb.(1028507.820000) Device disconnected: Hostname: android-​f5e234d9f9bbb121 IP: 192.168.1.82 MAC: f4:f1:e1:a5:c5:ee
08:55:27, 02 Feb.(1028507.820000) Device disconnected: Hostname: PS4-​00-​d9-​d1-​61-​93-​f8 IP: 192.168.1.85 MAC: 00:d9:d1:61:93:f8
08:55:06, 02 Feb.OUT: BLOCK [9] Packet invalid in connection (tcp reset attack is suspected: TCP [192.168.1.85]:57100-​>[54.215.255.56]:443 on ppp3)
08:55:05, 02 Feb.OUT: BLOCK [9] Packet invalid in connection (tcp reset attack is suspected: TCP [192.168.1.85]:62834-​>[54.68.195.242]:443 on ppp3)
08:55:05, 02 Feb.BLOCKED 1 more packets (because of Packet invalid in connection)
08:55:04, 02 Feb.OUT: BLOCK [9] Packet invalid in connection (tcp reset attack is suspected: TCP [192.168.1.85]:54736-​>[54.68.102.34]:443 on ppp3)
08:54:59, 02 Feb.OUT: BLOCK [9] Packet invalid in connection (tcp reset attack is suspected: TCP [192.168.1.85]:56599-​>[54.68.102.34]:443 on ppp3)
08:54:51, 02 Feb.IN: BLOCK [9] Packet invalid in connection (tcp reset attack is suspected: TCP [23.195.112.217]:443-​>[81.141.30.159]:53573 on ppp3)
08:54:48, 02 Feb.(1028468.200000) Lease for IP 192.168.1.85 renewed by host PS4-​00-​d9-​d1-​61-​93-​f8 (MAC 00:d9:d1:61:93:f8). Lease duration: 1440 min
08:54:48, 02 Feb.(1028468.200000) Device connected: Hostname: PS4-​00-​d9-​d1-​61-​93-​f8 IP: 192.168.1.85 MAC: 00:d9:d1:61:93:f8 Lease time: 1440 min. Link rate: 1000.0 Mbps
08:54:48, 02 Feb.(1028468.080000) Lease requested
08:54:42, 02 Feb.(1028462.670000) Device disconnected: Hostname: Xbox-​360-​00-​25-​ae-​85-​0f-​e2 IP: 192.168.1.76 MAC: 00:25:ae:85:0f:e2
08:54:42, 02 Feb.(1028462.660000) Device disconnected: Hostname: android-​f5e234d9f9bbb121 IP: 192.168.1.82 MAC: f4:f1:e1:a5:c5:ee
Perhaps it's dropping everything and not just the PSN? Perhaps I've only noticed it on the PSN but it's happening to every device. It certainly looks that way!
