woobl
Message 1 of 5
Infinity extension - What wires go where for RJ11 in extension box?
Hi all,
I had the engineer over today to install Infinity. Everything working good and he left me some CAT5 and an extension box as I want to extend the line to different part of the flat at a later date. However, I fancied doing it now but am having some issues getting the extension to work. I've followed the engineer's instructions which were:
Faceplate off and CAT5 single strand into 2 and 5 on the extension point (orange in 2 and orange/white in 5)
Now I cant' seem to figure out where the orange/white etc goes on the extension box - does it go into 4 and 5? This will be for an RJ11 connectotr o the homehub.
Here is the extension box: photo.JPG
Any ideas?
Many thanks!
4 REPLIES 4
Deathtrap3000
Recognised Expert
Message 2 of 5
Re: Infinity extension - What wires go where for RJ11 in extension box?
Pairs match up to the colours...
Blue pair is first. Connected to the matching terminals on the cat5e socket and onto the terminals on the faceplate.
Nothing should be in 2 and 5 if its an extension for infinity as the filtered faceplate filters it all out of the phone wiring.
woobl
Message 3 of 5
Hi Deathtrap3000,
I'm a little confused...
On the master socket, I connected white to 5 and blue to 2. Where does the corresponding end connect to in the photo above? Does the other (orange/white) cable need to be connected as well?
Thanks!
woobl
Message 4 of 5
Figured out what was the issue - I was going into the phone line extension conections - not the DSL connections that were on the other part of the faceplate!
Deathtrap3000
Recognised Expert
Message 5 of 5
Yep thats what I was trying to say. 2 and 5 is for the phone line. Not the dsl, unless its not filtered.
