markandnicola
Message 1 of 10
Infinity 'fibre to the home' not working - LOS red light
I have Infinity 'fibre to the home' and woke up this morning to find the 'LOS' light be solid red and no internet connection.
Tried powercycling and rebooting etc. but no luck.
Anyone come across this issue before?
See attached.
Thanks,
Mark
9 REPLIES 9
Guru
Guru
Message 2 of 10
Re: Infinity 'fibre to the home' not working - LOS red light
markandnicola
This means that there is no Optical data connection to your ONT.
Have you checked the cables and the optical connector to see if there is any issues there?
Also go to http://www.bt.com/consumerFaultTracking/public/faults/tracking.do?pageId=31&s_intcid=con_fly_help_po... to see if there is any issues in your area
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
markandnicola
Message 3 of 10
No errors showing in my area.
Will double-check cables after work.
Download speed went down to around 2mb from usual 50+ last night and then this error this morning.
Guru
Guru
Message 4 of 10
There have been a few posts about FTTP connections going down. If the issue is still their when you get back from work, you could try calling the FTTP Helpdesk to see if they can diagnose any issues.
Try a Search
markandnicola
Message 5 of 10
Do you know what the FTTP contact number is?
Guru
Guru
Message 6 of 10
Sorry for the delay markandnicola
You can try  0800 111 4567. The system should route you to the correct team.
If you don't get anywhere with the helpdesk and the service is still down then a Mod may offer you their help.
Try a Search
markandnicola
Message 7 of 10
Unplugged and plugged all cables and power leads back in and Openreach box working again.
Download speed down to 2meg rather than usual 50+ but upload consistent at around 20.
I spoke to a neighbour and he is having similar issues so at least I know it's not the BT equipment in my flat.
He said an engineer is visiting today so hoping to hear more later.
hippey
Expert
Message 8 of 10
Which exchange?
Always worth removing the power for the modem to see if it will resync, occasionally works but very rare you need to do it.
markandnicola
Message 9 of 10
Capel in Surrey I think.
markandnicola
Message 10 of 10
All sorted last night. Assume engineer who came for my neighbour sorted it out.
