zeb
Message 1 of 3
Infinity install - quick question about logistics
Hi
I have the FTTP box installed outside my house and am awaiting the activation date/internal work. The box has been placed at the opposite end of the house to my master socket. I have walls 2-3 feet thick. Will this cause any issue for the final stage of the install? (am alittle cautious maybe as its been a bumpy ride getting to this point - my original activation date was 2 months ago)
Thanks in advance
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: Infinity install - quick question about logistics
Hi and welcome to the forum.
The engineer will have the appropriate drill bits to be able to drill through the walls, he will then run the fibre tubing from where your current socket is back to that fibre spicing point outside.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
zeb
Message 3 of 3
great - thanks!
