PaulFromHere
Message 1 of 5
Infinity speed down from 20 to 2Mbps
Please can someone advise on the best way to progress an unresolved fault with my Infinity? I reported low speed to BT on 24 Sep 2014 and the remote testing that was done did identify a fault. Someone came out to fix it and the speed improved (from about 2Mbps to about 8Mbps) for a while but not up to the 20ish Mbps that I used to get.
The fault is still showing as open on my BT account. For various personal reasons I have not had a chance to get back to BT until now, but I don't want to spend hours trying to get through on the phone or the online chat to India that I used before.
The speed is now back down at less than 2Mbps as shown below:
Tags (2)
4 REPLIES 4
Distinguished Guru
Message 2 of 5
Re: Infinity speed down from 20 to 2Mbps
If you have a fault, you'll need an engineer's visit to get it fixed.
If not, I'll try again 🙂
Message 3 of 5
please edit your phone number out this is a public forum viewable world wide
PaulFromHere
Message 4 of 5
Oops. Thanks John
astar27
Expert
Message 5 of 5
