Message 11 of 14
Re: Infinity throughput issue
I don't think that download speed will be classified as suffering congestion and is nowhere near the very poor 2mb in your initial post
NeilJohnson
Message 12 of 14
No, it's nowhere near as bad as the 2Mbps (which should have been logged on the BT Wholesale server). I'll post another snapshot next time it plungs that low!
So, how poor does my download speed have to be for it to be considered that there's a throughput/congestion issue? Is 66% of my sync speed with a 122ms ping considered perfectly acceptable? And is never seeing >80% of my sync speed also considered acceptable?
Thanks,
Neil
Message 13 of 14
The btspeedtester only retains the last test run so if you do get very low download speed then don't run any further tests
NeilJohnson
Message 14 of 14
Thanks @imjolly - that's very useful to know as I'd assumed everything seen in the 'further diagnostics' tests would be logged!
