Message 1 of 16
Installation of full fibre broadband
I live in a rural and Openreach confirm we can access full fibre broadband.  After a huge effort and discussion of detail of our address a date was set for the changeover.  Engineers said they couldn't complete the work as extra work needed completing outdoors.  We've heard nothing but a neighbour discovered they now require a road closure to complete the work, so we could be struggling for weeks.
We've been informed we can't return to the old system so basically have no broadband other than a dongle which doesn't work the central heating or TV properly.
In the meantime we're paying a premium for the cable system.
How do I get someone to listen,? Just feel like I'm on a merry go round.
No information forthcoming..
15 REPLIES 15
Message 2 of 16
I live in a rural and Openreach confirm we can access full fibre broadband.  After a huge effort and discussion of detail of our address a date was set for the changeover.  Engineers said they couldn't complete the work as extra work needed completing outdoors.  We've heard nothing but a neighbour discovered they now require a road closure to complete the work, so we could be struggling for weeks.We've been informed we can't return to the old system so basically have no broadband other than a dongle which doesn't work the central heating or TV properly. In the meantime we're paying a premium for the cable system. How do I get someone to listen at BT? Just feel like I'm on a merry go round.
Message 3 of 16
Re: Installation of full fibre broadband
Are you a BT broadband customer?
It is not BT who install the network, it is Openreach who do that and there is nothing BT can do to speed up the timetable that Openreach work to.
Message 4 of 16
I understand that Openreach are completing the work but it's hardly fair that BT don't reconnect us back to the old system.  They don't update us on the progress of the order for new cable system but seem quite happy to charge us the extra cost for it never mind £42 pcm for non existent broadband service.
Message 5 of 16
Just looking at Openreach site they clearly say that any complaint on installation has to go through your provider..
Message 6 of 16
Which is why I asked if you were a BT Broadband customer.
In any event if you want to complain to BT you can not do that on this forum. You would need to call BT 0330.1234.150
Message 7 of 16
Well I've evidently misunderstood the purpose of the forum. I've phoned a number of times without getting any resolution. No real complaint system available either.
I'll check out now.
Message 8 of 16
The fact you need to go through your provider is why you were asked who your FTTP provider is , if it isn’t BT then this forum is not the for you to be , TBH , you still haven’t really confirmed that BT are your new FTTP  provider, but I’ll assume they are .
FWIW , there is no reason why the old service needs to be ceased if there is a delay with the provision of the new service, in fact the OTS , one touch switching system has checks etc to avoid this issue , basically if the new service isn’t provided , the OTS system message to close the old service shouldn’t be sent , therefore the old service should remain active until confirmation that the new service is in and working , that suggests either the OTS system wasn’t used correctly, that could be your error or the FTTP company  error , or even Openreach if they said incorrectly that the new service was provided or the damaged the old service trying to install the new service …..just for clarity, are BT your provider for both the new FTTP and whatever service FTTC/ADSL you had previously, of they are the new provider for FTTP but you were using someone else previously, or BT are not involved at all .
If you have been given a mobile device to provide some service during this period with no landline type service, even if it isn’t particularly useful, it’s more than most providers supply , if you used someone else (not BT/EE ) you would be facing the same issues but without a temporary mobile service supplied .
Message 9 of 16
Okay thanks that's helpful.
We have been BT customers for 38 years at the same address.
There has to be a reason why they switched off the old system on the morning that the new cable system was due to be set up.
We look like struggling for weeks without decent broadband connection.  We're long term customers, retired, live in a rural location and my husband is awaiting updates on ongoing cancer treatment
I'll phone again to find out why we can't be connected to the old system and why they continue to charge us for service we don't receive.
Message 10 of 16
You won’t get reconnected to the old copper system if the error was the FTTP service was booked of as a successful installation when it wasn’t successful at all , in this case yiur copper service isn’t active and no new orders for the old products can be raised , they system won’t allow old products to be ordered once FTTP is available , or Openreach (or their contractor ) damaged the copper cables trying to install the fibre cables, in that case your copper service is still live but is disconnected and OR are not going to waste time repairing copper while simultaneously trying to fix whatever the FTTP problem is …..what makes little sense is the talk of road closures etc , the CBT (fibre distribution point ) should already be ‘ready’ to give service to you and possibly others nearby , and be relatively close (pole outside , jointbox outside ) if it isn’t then you shouldn’t have been able to order FTTP in the first place (regardless of the upgrade to FTTP being initiated by you or BT ) .
