latitudehopper
Message 1 of 22
Installed today - only getting 10mbps, was told 76
This cannot be right can it? It is a new house, close to exchange. Filters installed. All the usual checks done.
1. Product nae:BT Home Hub
2. Serial number:+068543+NQ44100664
3. Firmware version:Software version 4.7.5.1.83.8.173.1.6 (Type A) Last updated Unknown
4. Board version:BT Hub 5A
5. VDSL uptime:0 days, 01:07:19
6. Data rate:6733 / 30731
7. Maximum data rate:6800 / 30968
21 REPLIES 21
latitudehopper
Message 2 of 22
Re: Installed today - only getting 10mbps, was told 76
Just tried again and I am getting the 30 shown, but I signed up for infinity2....
Distinguished Guru
Message 3 of 22
You missed the important stats, please supply lines 1-13
If not, I'll try again 🙂
latitudehopper
Message 4 of 22
Apologies
Product name: BT Home Hub
2. Serial number: +068543+NQ44100664
3. Firmware version: Software version 4.7.5.1.83.8.173.1.6 (Type A) Last updated Unknown
4. Board version: BT Hub 5A
5. VDSL uptime: 0 days, 01:17:33
6. Data rate: 6733 / 30731
7. Maximum data rate: 6783 / 31143
8. Noise margin: 6.1 / 6.4
9. Line attenuation: 0.0 / 26.0
10. Signal attenuation: 0.0 / 23.2
11. Data sent/received: 206.1 MB / 821.1 MB
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: No
Message 5 of 22
Can you run this checker and post back a screen shot of the results
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
and use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
Distinguished Guru
Message 6 of 22
It's the distance to the cabinet that's important, not the exchange.
For your attenuation, the data rate is in the right area.
latitudehopper
Message 7 of 22
1. Best Effort Test:
Download Speed : 4.53 Mbps
2. Upstream Test:
Upload Speed : 5.89 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date  High Low High Low
FTTC Range A (Clean)80802020--Available
FTTC Range B (Impacted)8057.8205--Available
ADSL MaxUp to 4--3 to 7Available
Fixed Rate2----Available
Other Offerings
Fibre Multicast------Available
Message 8 of 22
Obviously there is a problem. As Ray has said your stats on the Homehub show that your download stats are about right for the line attenuation but they do not tally with your speeds as per the speed test or what your estimated speeds show.
Are you on Infinity 1 or Infinity 2. If you are using a filter I assume you have had a self install which is normally only with Infinity 1 unless your line can deliver the max for Infinity 2.  In any event you will need to contact BT and ask them to send out an engineer to investigate the problem.
latitudehopper
Message 9 of 22
How odd. Self install but infinity2, using filters sent with homehub. I know the speeds they throw about are estimates but the order system said We estimate your download speed will be between 79Mb and 80Mb. Even if wrong, 30 is a way off 79.... Thanks for the input.
Distinguished Guru
Message 10 of 22
What's the status of your phone wiring at home?
Are you using any aluminium extension cables?
