Message 1 of 35
Installing third party router
Im trying to install the  ASUS RT AC88U however, the router isnt detecting any internet from the modem. I can access the  admin page and set everything up but, I have no access to the internet
Do I need to do anything specific with the BT modem?
34 REPLIES 34
Message 2 of 35
Re: Installing third party router
It states that the WAN cable is disconnected.
Message 3 of 35
you need to connect the openreach ONT to your Asus WAN port  you also need to enter username  bthomehub@btbroadband.com  and if password needed then most just use BT but anything will do
Message 4 of 35
Oh thank you for that. I will report back once I a try this. 🙂
Anonymous
Not applicable
Message 5 of 35
Make sure that the WAN Connection Type setting is set to PPPoE
Message 6 of 35
Unfortantely, this did not work for me. It still states that the cable is disconnected. Ive taken some photos of my steps just incase.
Message 8 of 35
Can't see anything on those images. Please take screenshots and post them directly on the thread.
Message 9 of 35
Sorry guys and gals, soon as I hit post, it filps the
Anonymous
Not applicable
Message 10 of 35
The images are too small and too poor to be of any use, can you post them in a higher resolution
