Message 1 of 8
Interleaving
Hi,
Interleaving has just enabled on my conection doubling, nearly trippling my latency, can a mod kindly turn this off as my connection has been fine until now.
thanks
7 REPLIES 7
Message 2 of 8
Re: Interleaving
Welcome to this user forum. @danutz
Its not possible to turn of interleaving on a VDSL connection.
Message 3 of 8
Re: Interleaving
Thank you for the quick response Keith however I have to disagree as its been off since last year when a BT engineer reset my line.
my latency has gone from 8ms to over 20 since Friday evening, checking line stats I can see interleaving has been enabled.
# xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 0
Last initialization procedure status:   0
Max:    Upstream rate = 18854 Kbps, Downstream rate = 57244 Kbps
Bearer: 0, Upstream rate = 18653 Kbps, Downstream rate = 55245 Kbps
Link Power State:       L0
Mode:                   VDSL2 Annex B
VDSL2 Profile:          Profile 17a
TPS-TC:                 PTM Mode(0x0)
Trellis:                U:ON /D:ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):        6.3             6.1
Attn(dB):        19.5            0.0
Pwr(dBm):        6.9             6.6
                        VDSL2 framing
                        Bearer 0
MSGc:           16              20
B:              51              222
M:              1               1
T:              66              30
R:              12              14
S:              0.0374          0.4002
L:              15564           5074
D:              1               1
I:              64              255
N:              64              255
PS C:\Users\DanDu> ping google.co.uk -t -4
Pinging google.co.uk [172.217.23.3] with 32 bytes of data:
Reply from 172.217.23.3: bytes=32 time=8ms TTL=54
PS C:\Users\DanDu> ping 216.58.206.35 -t -4
Pinging 216.58.206.35 with 32 bytes of data:
Reply from 216.58.206.35: bytes=32 time=8ms TTL=54
Now
Status: Showtime
Retrain Reason: 1
Max: Upstream rate = 18946 Kbps, Downstream rate = 56424 Kbps
Bearer: 0, Upstream rate = 18973 Kbps, Downstream rate = 50076 Kbps
Mode: VDSL2 Annex B
Trellis: U:ON /D:ON
Down Up
SNR (dB): 6.1 6.0
Attn(dB): 19.3 0.0
Pwr(dBm): 6.9 6.8
VDSL2 framing
Bearer 0
MSGc: 18 14
B: 51 238
M: 1 1
T: 64 33
R: 12 16
S: 0.0330 0.4010
L: 15496 5087
D: 981 1
I: 64 255
N: 64 255
Reply from 172.217.23.3: bytes=32 time=20ms TTL=54
Reply from 172.217.23.3: bytes=32 time=22ms TTL=54
Reply from 172.217.23.3: bytes=32 time=21ms TTL=54
Reply from 216.58.206.35: bytes=32 time=20ms TTL=54
Reply from 216.58.206.35: bytes=32 time=21ms TTL=54
Message 4 of 8
Re: Interleaving
You asked whether the moderators can do it, they cannot.
If you have a broadband fault, then Openreach can reset the line, once the fault is fixed.
Message 5 of 8
Re: Interleaving
Interleaving cannot be turned off by anyone. DLM can be reset which may or may not result in interleaving being removed. Even if it is removed, DLM may decide it is necessary again at some point.
Message 6 of 8
Re: Interleaving
DLM was reset, Interleaving was removed, latency has returned to normal and has been running perfectly for over a month.
Message 7 of 8
Re: Interleaving
Status: Showtime
Retrain Reason: 0
Max:    Upstream rate = 21010 Kbps, Downstream rate = 56304 Kbps
Bearer: 0, Upstream rate = 20000 Kbps, Downstream rate = 58396 Kbps
Mode:                   VDSL2 Annex B
Trellis:                U:ON /D:ON
                Down            Up
SNR (dB):        5.7             6.0
Attn(dB):        19.1            0.0
Pwr(dBm):        6.6             6.6
                        VDSL2 framing
                        Bearer 0
MSGc:           19              150
B:              239             236
M:              1               1
T:              64              5
R:              0               16
S:              0.1308          0.3771
L:              14680           5410
😧              1               1
I:              240             255
N:              240             255
C:\Users\DanDu>ping google.co.uk -t -4
Pinging google.co.uk [216.58.206.67] with 32 bytes of data:
Reply from 216.58.206.67: bytes=32 time=8ms TTL=54
C:\Users\DanDu>ping 216.58.206.35 -t -4
Reply from 216.58.206.35: bytes=32 time=9ms TTL=54
Message 8 of 8
Re: Interleaving
the DLM reset did not remove latency interleaved but the reset changed the latency to fast.  should your line have problems as seen by DLM then it can and will change latency back to interleaved
