Message 1 of 5
Intermittent PPP Session Failures & Packet Corruption (ERR_SSL_BAD_RECORD_MAC_ALERT)
Hi everyone,
I’m hoping a BT Community Mod or network specialist can kindly help escalate a stubborn connection issue. For the past few months, I've been getting persistent ERR_SSL_BAD_RECORD_MAC_ALERT errors across secure HTTPS websites on all devices (both wired desktop and Wi-Fi mobile). The issue completely vanishes when browsing on mobile data, isolating it to my BT broadband connection.
I have run extensive local network diagnostics via Command Prompt and the BT Connection Tester, which points directly to an authentication/gateway routing issue on the BT network side.
  1. Diagnostic Pings and MTU Restriction:
  • Running standard unfragmented pings to Google with sizes 1472 and 1464 completely fails with the message: "Packet needs to be fragmented but DF set."
  • Manual testing reveals the absolute maximum unfragmented payload size the line will currently pass is 1460 bytes (locking the line's maximum working MTU at 1488).
  • I have manually updated my network interface configurations down to 1488 to compensate, flushed DNS, and tested custom public DNS to bypass potential server-side mangling, but secure packets are still getting dropped or corrupted mid-transit.
  1. BT Connection Tester Official Results: I ran the automated BT wholesale tester, and it explicitly flagged a network-side fault with the following output: "Test results: You might have some connection stability issues. This can result in your connection dropping out. Technical details: Your hub could be in sync with the exchange or cabinet, but not connecting to the gateway. If there's no PPP session it's likely to be a problem with our network."
I figure because the physical line syncs fine but the underlying PPP session is failing to authenticate cleanly with the gateway, my secure web traffic is having its cryptographic handshakes broken, triggering the SSL MAC errors?
Could a moderator please look into this, check my error/interleaving rates on the line, and order a port reset or clear any hung/stale PPP sessions at the gateway exchange end?
Or any suggestions at all on how to resolve would be hugely appreciated - I've spent months trying to resolve to no joy.
Thank you in advance!
4 REPLIES 4
Message 2 of 5
Re: Intermittent PPP Session Failures & Packet Corruption (ERR_SSL_BAD_RECORD_MAC_ALERT)
Hi @evertonian88
Welcome to the community. We have lots of fantastic, knowledgeable users here that may be able to offer some advice.
My advice is to speak with our technical support team, so that they can run through some tests, check everything from our side and raise a ticket through your account, if needed.
Please keep us updated here with what happens.
Chris
Message 3 of 5
Thanks @Christopher_G I did call - went through steps, no joy. The outcome was they proposed as a 'gesture of goodwill', cancelling contract (which was due for renewal in September) with immediate effect. This was after the agent spoke to tech support who felt it was an IT issue - after proving the issue occurs ethernet/wifi/across 10+ devices and after 4 routers being tested. A private network engineer also confirmed the issue was BT side. Customer of 10+ years, never had an issue before - this was the first - the proactive "we cant see anything so lets cancel your contract" felt very strange to me?
Message 4 of 5
Thanks for the update, @evertonian88
These types of issues are usually investigated by our technical support team, then escalated through the levels to try and find a cause and fix. Cancelling the contract early is usually reserved for exceptional circumstances, as a last resort. I'm really surprised that this was offered as a solution.
I'll send you a private message to get a bit more information.
Thanks.
Chris
Message 5 of 5
Hi @evertonian88 Did you get the Stale PPP Session Fault resolved, because believe it or not, I have had the same issue for over 3 years. I clearly don't have the same technical expertise as you, but from my humble perspective, the issue seems to be that whatever remote testing mechanisms are being used, they cannot detect a temporary loss of signal to the ONT. As such, we are forever going around in circles, because I am continually being told that my issue is internal. However and intriguingly, I have been receiving the same Network error reports c/o the BT Smart Assistant, on an almost daily basis, since mid October 2025. My own position has been complicated by the fact, that BT are refusing to enter into any correspondence with me, having placed my original complaint in "Deadlock", in September 2023.
