jmedwards
Message 1 of 2
Internal phone wiring
Hi,
I am having BT Infinity installed on Friday. However, I am not sure if my internal phone wiring will be up to the job. At the moment the external cable comes into the flat via bedroom window. Then it travels to the middle of the flat where there is some messiness involving what I think is either a master socket or an extension socket and a disused remotely monitored house alarm.
If this configuration (which I expect to be sloppy) causes a problem, would the engineer be able to simply 'cut' the cable at the bedroom and install a new master socket for me?
1 REPLY 1
Message 2 of 2
Re: Internal phone wiring
The engineer should be able to tidy it all up for you. Internal wiring is one of the engineering modules that comes as part of the FTTC installation mate 🙂
